HKS had the 3 kits (single turbo, twin turbo and supercharger) at SEMA, my pick was the twin turbo kit. My reasons for not choosing the the HKS supercharger kit are pretty much the same as for the Stillen kit, except for the whine of course. Both the supercharger and single turbo kits come complete, every required nut, bolt, washer and clamp is included. Compared to the twin turbo kit which leaves a fair bit to be fabricated on the inlet side.
Although it's a perfectly acceptable solution, I am not a big fan of the single turbo kit. I don't like the cross over exhaust pipe, the heat transfer into the rear of the engine block and, to a lesser extent, the firewall. Plus it adds distance between the RH bank of cylinders and the turbo while placing the LH bank right at the turbine. This manifests itself as minor differences in exhaust gas temperature and turbine acceleration (lag if you like). With the single turbine exhaust you end up requiring a diverging ("adaptor") pipe to get a twin exhaust system to fit. To me a twin turbo system on a V engine seems a much more logical solution and also offers some technical advantage to do with the packaging compromises of a single turbo.
That said, the single turbo would be easier to comply, emmissions wise, as the single cat would come up to temperature faster. But Nissan managed to get the R35GTR to comply, so its obvioulsy possible to achieve with a twin turbo layout. To support that logic I received an email last night from a guy in the US that I talked to at SEMA and he had his Z33 with HKS twin turbo kit (GT2530's) complied using the standard cats.
Cheers
Gary
  • Replies 54
Cheers
Gary
i'vbe done a bit of a look into this HKS kit..
appears quite nice to me compred to the stillen kit, not too sure how the boost delivery would compare to a turbo setup.. anyone read much comparing centrifugal s/c setups to a turbo?
also, the current HKS supercharger kit appears to be the GT kit while their old kit is the rotrex kit. not too sufe if these are different but i have seen them referred to differently.. i wonder if they chagned the design recently?
either way it appears to be well constructed and fits under the stock bonnet without much fuss..
my current thinking is whether the kit requires extensive tuning as i know there are very few HKS certified tuners across australia. many of these "complete" systems come pre-tuned so that might help its cause.
i might look into this a bit more!
Warren, I have had a look at this a while ago and also liked the stillen kit as it offered everything, whilst maintaining a good price. What stopped me was the bonnet. I hated the look of the aftermarket bonnets on offer and I also doubted their legality (as not metal and would effect crumple zones) thus effecting insurance.
On other another note, there is not a lot of room if useing a centrifugal supercharger. This would also take away any chance of keeping the stock air box as they are placed almost right where the air box is located (probably most FI will do without this unfortunately).
I like more and more the twin turbo set up, but cannot justify the cost.
yeah the bonnet is an issue for me..
the centrifugal kits seem to all lose the stock airbox, but no doubt an aftermarket airbox can be made to cover the supplied air filter and make it look more stock..
really, if it can be engineered to be legal, i don;t really care how the engine bay looks!
has anyone any experience with engineering products to be legal?
Warren, I'll get back to you on Monday when back in the office about you questions. Hope the info was informative.
Originally HKS contracted Rotrex for the supercharger but wasn't happy with the result so designed and built their own supercharger which currently can support 500hp with stronger engine internals.
Cheers
Marty
Sydneykid, I don't seem to be able to post up the pics of the HKS Twin Turbo Set-up Kit I have. This site doesn't like them. I'll have HKS send them again to me in another format and see how that goes. Or shoot me an email and I'll send the info. Sorry.
Regards
Martin
Edited by Martin HKS
  • 3 months later...
Dude, you'd be mad not to get a G35 Vortech Kit out of the US. I got mine from Performancefactory.com - cost me about $6k landed when the dollar was good. Came with everything, plug and play. Spent about 14hr fitting it myself, ECU worked like a charm and after a minor touch up tune ($200) i spun up 360RWHP with my 5AT drivetrain. ECU is easy to tune yourself/tuner on dyno. Cannot complain, easy to follow instructions, easy to upgrade the pulley for more boost etc - car response was phenominal!
PM me for more info if you want!
JK
Thanks Jai, I have been looking from a far at your car for sale. Wish it was a manual!
Looks good, but if (more like when!) I get an V35, I will start off NA and then maybe look at FI.
Have to get used to the steady flow of torque that my current car seems lacking.
Would the 6 speed cope with the S/C, in your opinion?
What boost can it go to?
Did it need a decompression plate as the std (18psi) is still quite high?
Edited by Stephen Thorpe
The Jatco Tranny is good, but definately not programmed to swiftly change when the RPM climbs alot quicker than expected aka forced induction. MT Automatics in SA do a quickshift kit for $700. Special removal proceedure for the Valve Body which Michael can send you.
No real complaints about the auto otherwise!
JK
why does it have to be manual? have you driven a 5AT V35? its an amazing transmission, nothing like the one in the R32/33/34...
Yes, the only V35 I have driven is an Auto and yes it was a good gearbox, but sorry I doubt that I will ever own an Auto, just not my thing.
I suppose if I compared it with other Aussie Vehicles and their Auto's, it would be like chalk and cheese, however it just doesn't float my boat.
JK
can you give me or pm me more details about the upgrade of the Valve body in SA?
What's the company that did it? any details? do you have to send your valve body there or swap?
Cheers
  • 8 years later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
