I recently had a 3" dump fitted and the original heat shield over the turbo and dump was removed.
Should I get some exhaust wrap on the dump?
How effective is exhaust wrap in reducing under bonnet temps?
www.flyn.com.au is selling 6m of fibreglass exhaust wrap for $48. Anybody using this stuff? Is this stuff any good?
https://www.sau.com.au/forums/topic/22793-should-i-be-using-exhaust-wrap/
  • Replies 55
Im looking into doing the same thing this coming week fo rmy new dump pipe. An estimate from an exhasut shop was that i would need approx 10m to do a 3" dump pipe. This would allow the dump/front pipe to be covered past the bottom of the firewall.
Add to this the expense of the clips to secure in place, and the coating to protect from the elements and i have decided to get the dump pipe ceramic coated. At approx $80 it is neater and perhaps better value, i cant say which works better as i have never used the exhaust wrap.
I have had my exhaust manifold and exhasut housing done by Competition Coatings and i have been happy with their work.
10mtrs was for dump and front pipe, as the front pipe normaly had a heat shield that goes all the way down to the cat.
My thinking is they are shielded for a reason so want to do the same to be sure that nothing on the firewall/floorpan is damaged by the hot exhaust. (My old R31 used to cook the floorpan as i had the exhuast tucked up nicely to ensure good ground clearance.
With the exhaust housing of the turbine after a 30min drive you can hold your hand about 1" from the housing for about 15sec before things start to get hot, so would seem to be working. I wish i could have tested it with a thermocouple before/after but didnt want to have to take the turbo off after having instaled it as the coating takes about 4-5 days.
I'd definately recommend wrapping the dump. I'm having mine ceramic coated, then wrapped. The ceramic coating alone is enough to allow you to touch the dump/or exhaust manifold without burning yourself.
The secondary advantage to keeping the heat trapped in the exhaust gasses is that they help spool the turbo quicker:D
I imagine that it not only allows the turbo to spool quicker but it MAY also reduce back pressure as the gas has a faster velocity hence it gets out of there quicker allowing the motor to breathe a little better in the higher rev's?!?! Maybe... :)
Depends what material you use. I have heard of a number of stainless manifold cracking, but usually due to the poor choice in stainless type (there are many type with different compositions). My manifold is made from steam pipe, it has a much greater thermal mass, and therefore isn't prone to cracking like the thin-walled stainless.
I had a 3" dump of mild steel and the engine bay got bloody hot, so hot that I got paranoid so I wrapped it, which made a huge difference to underbonnet temps.
Have now fitted a stainless ceramic coated dump, and I dont think it is quite as cool as the heat wrapped mild steel, so I will be heat wrapping it aswell.
Having higher velocity in the exhaust, apart from spooling up the turbo quicker, can aid in cylinder scavenging. Also increased velocity decreases pressure, and back pressure is not your friend either:)
Bottom line, if it makes the car go faster/harder, its all good. People have been coating and wrapping manifolds/dumps/turbines for a long time for good reason.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
