  • Replies 55
Guest Robo's
Searched the internet last night in trying to find some results in any performance gain, but couldnt find anything in comparison with a dyno with any gain!!
Yes the theory sounds right, and a good example was, "hot oil flows quicker then cold oil" which was used as a reference to exhaust gases.
But i was looking for an actual, real to life gain, and couldnt find anything.
  Quote
That would be great.
If someone can post some before/after dyno results of the non/heat wrapped or even some before/after temps it sounds like a cheap effective modification.
When you guys say it makes the turbo spool quicker are you talking 100-200rpm or 500-700rpm ?
i had the same problem, changed my dump/front.........
if you want some real life proof: before i put the tape on i could smell burning plastic all the time and id lift the hood and it would be as hot as **** under there, and after i put on the tape the burning smell went away and it is no where near as hot under there anymore..
good idea if you ask me :D
The biggest thing I'd be concerned about is the exhaust rusting from beneath the heat wrap because of condensation. Can you get your exhaust painted/coated with heat resistant stuff while it's on the car? And then put the thermal wrap on top of that.
Although, my exhaust is stainless anyway, would that be resistant enough to corrosion?
Exhaust wrap is good stuff in my experience. When coating headers, the headers would still get hot and I would imagine you'd still burn yourself if you were working in the engine bay after the engine was running. The wrap on my exhaust previously allowed me to work in the engine bay after the engine was running if I had to with minimal worries. You could even touch the manifolds themselves without burning your hands - of course you couldn't leave them there very long!
I find it interesting that most Japanese tuning houses and drag cars use header wrap.....
GTS-t VSPEC, a guy in these forums (sorry I forget who) had his exhaust rust right through from beneath his heat wrap. He didn't say if he had mild or stainless though I think.
The problem is not condensation while driving obviously, but after you park and it cools down. It probably won't be a *major* problem if the car is garaged but heat wrap being cloth and therefore porous, it will absorb small amounts of water from the air especially when it has the cold metal underneath to help the condensation in the first place.
Anyway I'm pretty sure stainless will be ok. It's not rustproof, but it's rust resistant which is probably enough. It may be my biggest concern but it's probably not a major one :P
Tomeastlake81, so you can heat wrap the exhaust manifold too? How do you do that?
There is a little theory floating around about the increase in performance from coating and wrapping the dump pipe.
My thoughts are that as a hp modification its not worthwhile. Full stop. The theory about exhaust gases etc is correct, but if coating/wrapping was going to make a measureable performance gain then it is most likely going to be seen if done to an exhasut manifold. And then even most likely on a stressed race engine more then a road car.
But again i see the main reason for coating exhaust parts is in the search to drop underbonnet temps. There is numerous reasons alone why we should be trying to drop underbonnet temps. If you want performance increase then consider about every 4deg C at the inlet is worth approx 1% of engine power.
Has anyone ceramic coated the standard manifold ? Mine is pretty rusty and would require a bit of work to get it nice I guess - But I like the idea - Then ceramic coat the dump plus thermal wrap it !
The stock manifold is cast and is poorly designed. I wouldn't waste the money on it. Doing the dump then thermal wrapping it make sense though.
The other option is to have the manifold heat sheild ceramic coated, they would reduce the amount on heat radiated into the engine bay from the manifold.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
