  • Replies 55
Guest Robo's
Searched the internet last night in trying to find some results in any performance gain, but couldnt find anything in comparison with a dyno with any gain!!
Yes the theory sounds right, and a good example was, "hot oil flows quicker then cold oil" which was used as a reference to exhaust gases.
But i was looking for an actual, real to life gain, and couldnt find anything.
That would be great.
If someone can post some before/after dyno results of the non/heat wrapped or even some before/after temps it sounds like a cheap effective modification.
When you guys say it makes the turbo spool quicker are you talking 100-200rpm or 500-700rpm ?
i had the same problem, changed my dump/front.........
if you want some real life proof: before i put the tape on i could smell burning plastic all the time and id lift the hood and it would be as hot as **** under there, and after i put on the tape the burning smell went away and it is no where near as hot under there anymore..
good idea if you ask me :D
The biggest thing I'd be concerned about is the exhaust rusting from beneath the heat wrap because of condensation. Can you get your exhaust painted/coated with heat resistant stuff while it's on the car? And then put the thermal wrap on top of that.
Although, my exhaust is stainless anyway, would that be resistant enough to corrosion?
Exhaust wrap is good stuff in my experience. When coating headers, the headers would still get hot and I would imagine you'd still burn yourself if you were working in the engine bay after the engine was running. The wrap on my exhaust previously allowed me to work in the engine bay after the engine was running if I had to with minimal worries. You could even touch the manifolds themselves without burning your hands - of course you couldn't leave them there very long!
I find it interesting that most Japanese tuning houses and drag cars use header wrap.....
GTS-t VSPEC, a guy in these forums (sorry I forget who) had his exhaust rust right through from beneath his heat wrap. He didn't say if he had mild or stainless though I think.
The problem is not condensation while driving obviously, but after you park and it cools down. It probably won't be a *major* problem if the car is garaged but heat wrap being cloth and therefore porous, it will absorb small amounts of water from the air especially when it has the cold metal underneath to help the condensation in the first place.
Anyway I'm pretty sure stainless will be ok. It's not rustproof, but it's rust resistant which is probably enough. It may be my biggest concern but it's probably not a major one :P
Tomeastlake81, so you can heat wrap the exhaust manifold too? How do you do that?
There is a little theory floating around about the increase in performance from coating and wrapping the dump pipe.
My thoughts are that as a hp modification its not worthwhile. Full stop. The theory about exhaust gases etc is correct, but if coating/wrapping was going to make a measureable performance gain then it is most likely going to be seen if done to an exhasut manifold. And then even most likely on a stressed race engine more then a road car.
But again i see the main reason for coating exhaust parts is in the search to drop underbonnet temps. There is numerous reasons alone why we should be trying to drop underbonnet temps. If you want performance increase then consider about every 4deg C at the inlet is worth approx 1% of engine power.
Has anyone ceramic coated the standard manifold ? Mine is pretty rusty and would require a bit of work to get it nice I guess - But I like the idea - Then ceramic coat the dump plus thermal wrap it !
The stock manifold is cast and is poorly designed. I wouldn't waste the money on it. Doing the dump then thermal wrapping it make sense though.
The other option is to have the manifold heat sheild ceramic coated, they would reduce the amount on heat radiated into the engine bay from the manifold.
    • It might be worth having a good look at the chassis behind the bumper then; most people prefer the series 2 look so it might have been changed to cheaper parts as part of an earlier repair
    • The car itself a series 2. I was just curious about the headlights and just wanted to confirm that they were series 1. Good to know the rest of the front end is series 1. It’ll be easier for me to find parts on the aftermarket side of things lol
    • If you've wired up the coils & injectors properly, & have the neo CAS loom for the trigger, it should all work. The VCT works the same way so just different plugs between s1 & neo. Assuming DBW if no IAC. Don't bother with the stock boost solenoid with g4x.
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
    • Light should be a pressure switch, not a sensor.
