Item: Protex 1 and 1/16th inch Brake master cylinder
Age: Fitted Brakes Bleed, driven onto Trailer and done 1 race meeting at wakefield (20 laps total)
Condition: Perfect condition, drained and back in the box
Price: $180
To Fit: Any nissan
Contact: Via PM
Comments: Good upgrade compared to the old original 15/16ths masters getting around. It does not have an internal proportioning valve but can point buyers in the right direction for a good quality item. I was using it with brembos and had a nice firm pedal with good stopping power. It has two outlet ports for use with ABS systems or can use without ABS and split the front line into two with a junction point (how I used it)
Only reason for sale is I have now upgraded to a boosterless pedal box and dual masters so its no use to me.
Due to the lack of proporting valve It needs to have an external valve fitted to work properly.
https://www.sau.com.au/forums/topic/227974-1-and-116ths-master-cylinder/
Valves are roughly 80 bucks for one like this on Ebay Bias valve
Allow for cutting into the rear brake line and two fittings which are not expensive.
Alternativly I had my valve mounted inside the car with braided line runnin through to the rear. It cost me about 90bucks to set-up that way.
The original GTR masters are a 15/16ths item and the Z32 twin turbos have a 1 inch so im lead to beleive.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
