Coburg Drive-ins...Question??? Please
Originally posted by gtstii
if you have a jap stereo which has had the frequency converter attached - then it's no good to tune in.
If it hasn't had the converter installed, then your ok.
I think they use around the 80's MHz frequency mark
I know this has passed now but why would anyone broadcast any radio frequency in this country under 88Mhz ?
Seeing as ALL of the Aust-sold radio-enabled audio systems are 88-108 MHZ
/baffled
Guest RedLineGTR
Originally posted by JET-33
91.9 at one of the coburg screens rob :D
i know now after i we went thier...radio only went up to farken 90.0mhz dam it oh well at least they had speakers so it was okay. Might as well can thet converter soon (on the to-do-list)
It was a good night when the rain stopped.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
