Engine is complete and ready to drop in, Makes very impressive power and torque figures. The turbo set-up has been taken off for a new engine im currently building but im throwing in my old T04E and stock exhaust manifold.
Comes with:
Standard N/A rb30 block
Stock 25 Head / inlet
R33 oil pump
gtr N1 water pump
NICS 5 puck ceramic clutch / nismo springs in pressure plate. still bolted upto engine.
Sard injectors 650 cc
Cometic head gasket
New timing belt tensioners
Stock exhaust manifold with T04E
This engine has Zero blow-by.
Does not blow any smoke.
Compression within 5 psi on each cylinder (same to this day as when i built it) Running between 140-145 psi across all 6.
Rev cut was at 6,800 rpm.
serviced every 2000km's with motil competition 15W
Engine was tuned very safely at gt auto garage in brisbane.
Asking $2800 for the whole lot.
Located in Brisbane, Windsor.
Contact on 0413715944.
Cheers Kev.
Edited by kaige
https://www.sau.com.au/forums/topic/228047-rb-30-det-or-2530-engine-for-sale/
Jeebus/!!!
this is a BARGIN!!
you are mad to sell it for that you should be asking 4 grand.
1 in the hand is woth 2 in the bush, looking for quick easy sale.
This engine will not disappoint
Edited by kaige
making 390 rwhp and 470 nm atw. full boost (17-18 psi) at 3200 rpm.
came on very hard.
did not want to rev this engine past 6800 with stock r33 oil pump and block.
for anyone who comes to have a look i have dyno sheets.
running safe air/fuels and bugger all timming only revving to 6,800.
Edited by kaige
  • 3 weeks later...
OK im going to do a price list for everyone to show you how cheap this is.
rb30e - 250 (complete engine with spark plugs and original timming belt) $250
blown 25 - oil pump, knock sensors, loom and head ect... $1000
head gasket - $250
timming belt and 2 new timming belt tensioners - $230
gtr n1 water pump - $340
gaskets and oil seals, including rear main, crank and both cams - $ 200 at least
clean and check head, new valve stem seals, match head for the 30, add vvt with lines - $550
NICS clutch, has nismo springs and 5 puck button - $540
sard injectors - $600
t04e with dump pipe thrown in as well!
TOTAL $3960
NOT including turbo and labour!
