  • Replies 95
I took my bike out and managed a 11.5 @ 132 mph. Having a few problems getting it off the line, and only got three runs in (first time out on the bike too).. so not enough time to try a new technique that I hope will put me into the low 11s. It was certainly different from going in my cars :P
7HEAVN car sounded awesome... hope it's an easy fix.. sounded like some of the teeth stripped from the rear diff?
may come out an watch or race but i'll be out there
Hey, nice to meet you.. hope you had more luck getting off the line after I spoke to you :)
nice to meet you to tommo. didn't end up getting another run due to the rain. cold track, street tyres, and slipping clutch = no good :P
nice to meet you brett ( 7heavn) what happened at the end. hope it's nothing to serious.
besides cacklingpipes what are the other WSID photograph websites?
badgerphotography
just type "wsid pictures" in google.
mate only a 13.5@108???
how much power have you got? I thought you had 240+kw
trap speed should be higher....
no traction?
mate I ran a 13.4@106 on 205-210kw. street tyres. still prob got a 13.3-13.2 on streets, should crack a 12 with slicks.
stock suspension really helps, last skyline had coilovers and just broke traction 2nd for way too long.
60ft???
best was 2.2 60ft
I was running on 14psi which is about 220rwkw
Seee man i am so confused
What am i do wrong
i have 270rwkw and i got a 2.3 60ft
and got 13.2 @ 114mph
i had street tyres 17/235/45 rear to be exact
how was traction???
thats really the only thing to explain that time....you got the mph 114 i think should be good for a 12.5...
chris not sure bout u tho cause mph isnt that much higher.
best was 2.2 60ft
What am i do wrong
Both of you guys need to work on your 60 footers. Practice and talk to other skyliners with similar power who know what they are doing. The advice I have received from 2rismo has been invaluable in this regard.
Of course it goes almost without saying but you would chop chucks off your times with drag radials. (I've got some for sale hint hint :thumbsup:)
how was traction???
I wheel spun all of first and second and abit in third
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
