AWESOME Andrew!!! :ninja:
Have you thought about Targa? Decided to enter Rookie to see if you can win modern to get the full entry for 2010 or just goin the whole hog?
Yep I'm looking at this Wrestpoint Rally, Targa Rookie and hopefully Mt Buller for 2009. Not sure about trying to win the Rookie however since neither me nor my nav have any Tarmac Rally experience so really we are just going out to learn what it is about and to have some fun and most importantly bringing home the car in one piece next year.
I'll probably be getting in your ear a bit over the next few months though as I try to sort all of this stuff out. Even this entry form looks daunting :P
Are you using the blue car? Be interested to see what you needed to do, full cage and all the other bits and pieces.
Yep using the Blue car. Already have been down to see Toby at Merridian to sort all of the safety / other generally rally stuff out (car will be down there in the next month or so to get it all done) and have also chatted to Benno about what I need to do to bring the car in-line with Rally regs which will all be done when I fix the diff. It's actually not so bad these days with the AASA rules (given things like oil coolers and radiators are much easier now).
So.....Wrest Point - im keen as mustard!
And for $2k you cant really go wrong given the amount of K's driven
EDIT: I rang the number on the bottom of the email to find out the exact rules regarding cages - does anyone here know 100% what the rules will be? I have a bolt in half cage sitting here i can put in, not really looking to get a full weld in cage
Ok, ill have a look at what they cost and weigh it up :P
Helen came and asked me about half cages and R32 GTRs so putting two and two together she will call in the morning suggesting a CAMS approved Bond bolt-in system... allow $1200 for R32 kit. They are pre-fab and generally in stock ready to freight. No cutting trim required even with side intrusion so no real resale killer.
For a decent weld-in allow atleast $3500.
you're 3.0L motor isn't going to be all that legal either mate btw.....
Ok so thats a definate on the full cage....
Hahaha, thanks for that ill mention i spoke to you when she calls back :D
As Snowy said, ive got an rb30 bottom end, so it looks like i cant enter anyway - unless there's a class for people who just want to have fun and dont take it as seriously as the guys at the pointy end of the field?
Cheers :)
there is steve, mt buller sprint. its a drag race up the hill, about 8minute run and you get a heap of passes over 2 days. It doesn't run under these regs and allows more modified cars.
cool, helen is good value.
funny you should mention that... for 2009 with targa tasmania and targa wrest point we are introducting a class that will allow people to compete with modifications outside the tollerence of the technical regs.
providing cars meet all the safety requirments eg. cage, belts, kill switch etc you can run all stages at unrestricted pace, compete for a targa trophy, but not be classified under the final results.
That sounds like a good class :D
So in this proposed class for example, you would allow single turbo conversions on GTR's, Rb30 bottom ends, different gearboxes etc - that kind of thing? Or less mods than those :blink:
Looks like ill have to wait another year
Good news! Be keen to see what these rules entail Stu.
And you'd want to drive that through the trees without a cage....
You're pretty special Sunshine :D
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
