looks good andrew....but damn low. you need to be really careful with clearance it can't be anywhere near track level unless you are happy to do a sump :D
good luck with getting hold of tarmac's money guys. I would prefer to see the cover price I pay going to someone on here :)
Hey Dunc - the car will be raised next week. Even if for no other reason that so I can get a damn jack under it! Those side skirt extensions mean I only have 120mm clearance now. But I know from just some decent cruises that the car bottoms out on the exhaust so it was always going to be raised a bit anyways.
you know that problem (can't get a jack under it) really used to shit me....until someone pointed out the front tow points. You can get to them with any decent lowish jack no matter how low the car is. And if you have a good cage it should lift both sides of the car together.
Nice one Kel! When do you head over? And are you doing delivery vehicle duties again? We're on the Wed night boat.
Cheers :(
Not sure of travel arrangements and duties just yet - the Donut King guys are just back from racing the 24-hour in Dubai.
Good job boys. Thats a cracker of a classic car so you should have some fun. I'll have some beers on ice at the finishing line waiting for you! :P
PS - we expect at least 1 stage time faster in the R32 than you did in the R34 :P
Should be a cracker! Not sure where we could make up time, Georgetown perhaps? (sniggle :P )
Anyone care to explain how Outright Classic and Late Classic works? I take it one is a handcap or something?
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
