Tarmac Rallying Perpetual Thread
snowy was out on stage 1, looked like some mechanical issue since there was no obvious panel damage.
Kel and Pete made it home 8th overall, but it must have been a bad day for organisers - about half the stages skipped and a big roll on the first stage :P
Hey all,
What a start to my rally experience! 1st stage was a short non-timed warm up and all was well. 2nd stage was cancelled due to a Citroen being on it's lid which meant the massive 29km Geevston stage was to be my first timed stage. Despite all my talk of "taking it easy" etc we pretty much were cracking it from the get go. That was shown by the fact we were apparently the 2nd highest clocked speed through a speed trap early on in the stage.
Everything was going great and I felt really comfortable with the speeds and the car until around the 17km mark when I noticed the car was getting hot (water had hit 120degs) so I was forced to go up a gear and try and rely on corner speed. That was still going ok (and the temps were coming down) until the front right wheel fell off....
All 5 studs were completely sheared off - NFI why - but needless to say it brought us to a stop. Amazingly however other than the hub / rotor edge / inside of the wheel there isn't a single mark on the car. We made a couple of calls and found someone with some parts and the good news is we are back to fight another day! Fingers crossed we have a better run tomorrow.
Untill then.... :)
too tired to post properly but it was an awesome
day out - even with all the stage changes
shame some of the stages downgraded or cancelled were ones better suited to the skylines :)
Very sad to see Snowy parked at the side of what turned out to be our first competitive stage hope you guys get back out tomorrow
Will be interesting to see how tomorrows adventures on the goat tracks go :P
Andrew its probably too late now but most likely youv've just learned how much harder targa events are on the car than track. I would guess that the hub ring on your rotors does not match the ring on the wheels you are using.
the studs themselves are only to hold the wheel on the hub, not to hold the whole car to the tyre. the inside of the hub should be a snug fit on the lip of the rotor. If not you should sort out some hub locators for future.
all the best getting it sorted tomorrow.
Kel...go to sleep! You have a pet food car to catch :)
At least it wasn't a $2 part - studs are about $5 each aren't they? :)
Great to see that you can get going again tomorrow - well done guys.
Any word on what happened to Stephen Bradford?
Regards
Andrew
Hey all,
Untill then.... :P
Kel and Pete had an off 6km's into SS13 - All ok.
Bugger Kel you guys were going so well!
Thanks for the up-date mate. I was getting a bit worried about the princess.
Neil.
Umm why are those marks heading off the road?
Oh...I see.
Apparently it was only a minor fire too.
Tassies finest tow trucks to the rescue
Doesn't look to bad here....but I think there might be unpleasant surprises under the bodywork.
Anyway apparently they are both
but I think probably sore tomorrow. I guess Kel should have invested in a HANS before going out in the r35.....
Apparently poor road surface and a little too fast....just a little off.
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
