Jones had a comfortable margin in the end, Quinn was disqualified for an "exhaust irregularity" :D
good to hear, I beleive he has previously been warned about one or more "irregularities" in prior raliies as well. In my book if its not right you should be excluded, especially if you finish on the podium.
Well done Steve!
Klark Quinn was also excluded for running a 2.2L engine in his EVO.
It will be interesting to see the fall-out from all of that.
The stupid thing about TQ's car is that other than weight there is no real benifit been found for running the full exhaust systems in these R35's. So there is no real reason for him to be doing it.
A 2.2L in an EVO is a different matter however! I think it would be good to see them crack down on these strokers though as they seem pretty rife through-out the sport.
Hooray, well done to Steve for another win, and I'm stoked to see someone caught with a cheat spec Evo, might fright a few dozen other blokes into complying with the regs now! lol
I wonder what the exhaust thing was with Puppa Quinn, does anyone know for certain?
did anyone notice that quinn had a spec-v sticker on his car for Targa Tas? and have you seen some of the cool things Garage Saurus are finding on the spec-v that was never publisized (bigger turbos, bigger throttle bodies, and who knows what else)
Interesting about Quinn Jr, puts a bit of the question mark over other LWR cars.
Benny, If you entered it as a Spec V, who would have the knowledge base to argue about any of it's specs???? lol
The car has to be homologated in Australia before you can run it. Since nobody has a Spec-V here, you can't run a stock GT-R as a spec-V.
Good to see Steve win even when up against a modified GT-R.
Pretty pathetic that Tony Quinn didn't even get out of his car after the last stage to congratulate Steve, when everyone else (including his navigator) did.
I'm pretty sure only Nissan jp know all the goodies on the specv ATM. But as Targa West is a CAMS event the specv trick wouldn't work.
Hmm questionable in general? Yes
Questionable on LWR's part? No
Think back to the last LWR EVO that won Targa/RT etc That was pulled down in protest and found to be std capacity.
I think someone else has had their fingers in the pie there
He was most likely contemplating ending his life " i cheated and still lost , i got nothing "
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
