Good on ya Timmy! Just to let everyone know, Tim's been headhunted by hot steerer and great bloke Gavin James. These boys will give the Early Modern guys a red hot run in their non turbo 944 :happy:
GO LADS!
Gavin couldn't sell the car? Good work Timmy, you should be a good chance for a podium.
Thanks guys, was a major last minute decision, but will be a good one hopefully.
Haven't discussed service crew arrangements with Gav yet, but Ben are you and Damo servicing this year? Wouldn't be asking you to put yourselves out and service for us, but maybe help us with a splash of fuel?
I'm crewing for Dad, and Damo is crewing for Kerry. I can carry extra fuel for you, and i'll have tools/race tape/cable tie's on hand if needed. I image Damo will be the same, but you'll need to check with him
Still chasing some accomodation, floor space, a roof... anything in Strahan really just for two, as she is totally booked out :)
Have made many calls nationwide, there is zip!
And I really don't think queenstown is an option since, we most likely won't have a car down there and the road closes at 6:58am queenstown end :D
i see the mazdabaters are running e85, i'll be interested to see what their fuel econamy is like, and if the car arrives with a bathurst tank. rX8's are thirsty at the best of times, let alone with a turbo
I heard Glenney is concerned it won't make the distance over Arrowsmith.
I wonder how many cars we will find run out of fuel toward the end of the stage this year? Only person I know who isn't worried is Barry Oliver, he was quite comfortable the new GT3 RS would get through fine since its the same capacity tank as the GT2, but more economical.
might buy a drum of e85 and sell it for $10/l, 5k from the end of the stage.
can't see any issue with that as long as you buy it from the monopoly supplier at whatever price they deem fair :laugh:
hmmmmmm, im not sure if that looks like fun or is like one of those amusement rides that scares the shit out of you to the point that you cant wait for it to be over so you can get off.
the shots with the cliff is unbelievable. Hats off to you people...much respect.
Nine more sleeps and I'm there!
ps: nice to keep reliving those potato farming adventures boys :laugh:
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
