brb- off to Styx Valley Rally.
ok so I know it's not Tarmac, but it should be a bit of fun.
I'm joining Timmy in Tassie this weekend for the first round of the Tasmanian Rally Series.
Jumping into a little Mitubishi Cyborg with Aaron Reader - should be lotsa of fun.
Now can you Tasmanians organise some decent weather for me please?
...and Stu - how are entries looking for HC?
I heard a rumour on the weekend that the event was way overscribed and a waiting list had been create?
we finally got our slack arses into gear last week and sent Helen our entry- hope we haven't missed out?!
Scotty - THC website will be launched on the 15th and turns out my email has a technical issue sending out... will be fixed this arvo and demon deal pricing included!
Kel - Lots of people are coming to play and plan is to accomodate as many as possible
WooStar - Dont be like that gorgeous, just playin!
Well from what I see it is looking like a few showers, but the amount of rain is looking low. Anything has to be better than what we had last year!
http://www.weatherchannel.com.au/WeatherMa...ENA/temperature
Stu,
knowing all of those roads quite well you've picked the cream of the roads in the area. I had no doubt the Whitfield Rd especially the section under the power lines would be used, but will it be in both directions?
Just a question on the Eildon-Jamieson Rd as well, did you have to put much pressure on the Shire to seal that rd? Once sealed it will be beome quite a popular rd for people wanting an alternative route to-from Buller. Also what surface are they planning? Spray seal?
Looking forward to this ;)
I'm putting plans into motion to spend a few weekends down that way for recce ;)
Would be good if everyone makes public their travel plans in the Garden state for same and we may all be able to spend some happy recce times together! :down:
Oh how I do like a good recce fossic ;)
Joining me to. ill be in Aarons cousins car. the mighty blue bird. and the south of the state is a hole anyway so weathers never any good.
Stu,
Looking forward to this :banana:
Yeah Dan, both ways! Mansfield Whitfield Road will be split into three stages each way.
Re Eildon Jamieson Road, the shires had plans to seal and this has simply been bought forward. It will be in final prep as roadbase ready for sealing at THC so we will simply transport over it, but will be in good condition as sealing is due to take place in the week(s) after the event... hopefully with a year to cure it will make it one of the best targa stages to be found. The surface will be better than simple spray and rock speard which has pretty short life, expect to see something much the seal at the Jamieson end which is next up from spray.
Cage sounds like a good idea Jeff... you just can't trust those Queenslanders!... but if you can lend me the key that would be great, I'll be over Thursday to do the roadbook! Just leave the key under a pot plant if you like! :banana:
Cage sounds like a good idea Jeff... you just can't trust those Queenslanders!... but if you can lend me the key that would be great, I'll be over Thursday to do the roadbook! Just leave the key under a pot plant if you like! :bunny:
I think you might be a bit more trustworthy than Ben
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
