On topic, YT was telling me today how quick some of it is :P Double wish I was there I love the flat out in top gear stuff through real quick corners. :blink:
Also told me of the lack of guard rails.... I nearly pissed myself when he told me he changed some notes from "Triple Caution" to "Westpac"..... As in rescue chopper. Haha
Ha yes I think we might see some rather spectacular off's for THC compared to the usual Tassie ditches, slight hills and field plouging - although upside down in a barn will still remain my favorite. Lets hope everyones safety gear is well in check - there are comments every snow trip how dangerous those roads are.
I know they're not Nissans, I know there is a video thread, I hope it's not a re-post, but I was literally agape at this video. Hope you enjoy it too.
http://www.youtube.com/watch?v=kEOKck7WWvU
Actually that was me. The car wiggled a tiny little bit - mainly through the steering wheel - when we hit some standing water and I wasn't expecting it - but at 200km/hr it gave me a minor heart attack!
I think I would have pulled over and walked the rest of the stage after that!
saw your new car yesterday... VERY nicely put together bit of gear
Dan there is only so much we can do in a day given the distance from home.
I've worked out if we head up - drive each stage once and get some footage of it - then head home we still have to cover over 700kms in the day! It's going to be hard to do any meaningful recce without spending a whole weekend up there - which unfotunately is something I won't have time to do.
We're going up for THC Recee on Oct 23 and will HD video all the stages from my 993 Turbo. I'll upload some if anyone is interested just PM me.
Edited by martyboy26
I drove through a lot of the stages yesterday, after a days racing at Winton in the R35,
My car is a total mess after more than 25 kms of muddy dirt roads between stages
Don't think I'll both doing it after seeing the state of the roads
Day one is OK, just a bit dangerous in places, good roads thou.
Day two is just remote wilderness
Makes Arrowsmith look like suburbia
:laugh: Sounds like the Turbo will stay in the garage for Recce. Looks like the Pajero it is!
For anyone wanting to drive over the 28 and 10k stages on the Jamieson Eildon Road I certainly wouldn't take anything too flash as there is 14km section of road construction as detailed in the recce notes.
The 14kms is now 1000% better than it was just four months ago and will continue to be improved. There was hope of it having a seal on it for the event, but too much rain means it will more than likely just be compacted road base and only partly sealed... for 2012 it has potential to be the longest targa stage we've seen.
Jeff's right, on these two stages there are no houses, no business, no nothing... but we do have excellent communications, tracking and incident response!
Sorry if I sounded a bit negative about day two stages
I was very tired after a long day at the track (I'm old remember)
It was all a bit of a shock in the dark and running out of fuel
Maybe it will look better after a second drive with pace notes in hand
I think that the dangerous bits on day one will need tape along the road edges
to find where a car has gone off
it's a very very long drop into that valley
Anyone else been through there yet??
yeah there are some big drops that will have everyone's respect.
a lot of people have been through so far and some great feedback.
have you dusted off the two ton pussy yet?
I thought that the "two ton pussy" was not allowed back as we don't qualify for legends status because we have competed in the past 10 years,
although I would have thought that as this is our 18th Targa we must be getting close to legends by now.
14 years since it ran and we still get asked at most stages every year..... where is the "Two Ton Pussy"
and yes it is very dusty
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
