it's getting close now, just had my leave approved, and Damo and I will spent the long weekend doing recce.
Had my car out on the track week before last, need to get some time as baskerville to set the suspension up properly though.
who's GC8 you flogging?
Edited by sav man
I'm a fan of not getting arrested. Hence the racetrack, esp this close to Targa the coppas will be on the lookout for Targa recce.
Yeah goes well, very happy with it. I'm surprised how easy it is to drive, the lack of tourqe means it won't spin the wheels unless you clutch it. Got it into the 62's at Symmons, i've put some more boost and timing into it since then. E85 is on the way too.
Great news Ben, how does it go/ Do you like it?
The GC8 is one of Rallyschool's.
What is the go Timmeh?..... engine cactus?
Guru at Fitzgerald's says engine is fine, just head gasket which may have happened when split radiator hose way back at High Country, just wasn't showing up until engine was heat soaked... Find out next weekend when it gets a thrashing.
Cross fingers/Touch wood/pat head/spin around 3 times/throw salt over shoulders.
Otherwise ill let everyone know where the best bonfire is going to happen post Targa!
Well I completed my final shakedown on the weekend and can say this new car is finally pretty good. We found last week a cracked turbo intake pipe which obviously hasn't been helping! No idea how long that had been there because it hadn't been on a dyno since it was first built. We also have finally got the handling balance right so lets bring on Targa!
Less than a month to go!
Good news Snowdaddy! Have we got a confirmed 'crew' yet??
What cops? ours are all in court babysitting criminals. If your smart and recce in a silver falcon, people think you are the cops (as was the case twice during Rally Tas recce!)
i can second that bens new car is easy to drive. its a surprise to us both we havent discovered more faults with it as we are just 2 noobs building a race car from scratch. a few more bits to finish off yet thoe.
if i had of driven at symonds the other weekend i could have nudged a 60. its that easy to drive.
oh and the brakes are unreal for non asisted items.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
