Mostly cosmetic, bit now we are running E85 unrestricted, have to fit new injectors, surge tank etc as well as change it all over to Tarmac. Bodywork is done on it, suspension has been changed. plus it needs a tune too now :-(
The Longford Revival Festival site is coming along well... even after all the rain last week the grounds are good and the Flying Mile nice and clean now... ready for some max speed runs from the racers and exotics both old and new!!
Edited by t01-100
Yeh don't care about that since I can't go. More importantly whats the go with Day 2?
Looking forward to the Longford Festival, should be a great lead up to targa week.
Massive thanks to Stuart for getting the Radcam's down to us the night before the safari, pretty sure you must have raced down there as soon as we messaged you :-)
I'm arriving in Lonnie saturday. Will have the customary piss up at the Olde Tudor saturday arv/evening.... and this time, Dicky Johnson is joining us :)
we finally have a good 999 car.... eddie decided using other people's crap was too hard so he purchased quite a nice Emo 8, all prepped up :)
Hopefully the top of Rossarden has been washed away. I shit myself going over there!! LOL
I'm on the ferry tonight ready to get into it.
Well I haven't been out yet for a look, but I saw on the news last week the train bridge you pass under at the end of Rossarden stage just before turning back on the highway (where every one services) and the water was up to the bottom of that bridge!
Ooh Yay! Will be good to see ya! No doubt ill be trying to squeeze 5 days recce into 3 so maybe not till the welcome party.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
