Email sent Greg ;)
Mel texted me asking if I was doing it, and she said she had plans to.... maybe you should talk to her :P
The dirt looks like a lot of fun (to drive), but it's the pulling apart and fixing the grubby things I don't rate :)
^^^^ Thats the only lack of appeal to me of the dirt. I really like the idea of sliding around on a budget, but the ongoing servicing, repairs and maintenance, even if you run a clean rally and dont touch anything could get on my nerves abit. That said, i havent done it so am only speculating.
tarmac, as long as you dont crash, quick wash, fresh fluids etc, and away you go..
Hmmmm.. group C RX 7 turbo..... Anyone who will pay sensible money (see what I have done there Woo :) ) want to buy a Targa Prepped TME? Is CAMS logbooked so will be good to go for next year.
Does this also mean that the other CAMS rallies will fall in line regs wise with the Octogon rules (Targa West, Rally Tas, Mt Stuart etc)??
Be good if there was just one set of rules thats for sure.
+1, good call
I would say its only a matter of time. The CAMS regs are one reason I cant be arsed respeccing my car and running at Targa West.... the shite roads and repeated stages is probably the other. :)
CAMS have already relaxed their rules on exhausts. I expect injectors and fuel pumps etc will come soon to embrace the E85 phenomena. Then its just the silly ones like adjustable strut tops etc to get rid of and you are just about there.
All this talk of new projects has tempted me to put the EMO on the market. I am asking crack pipe money for it on MY105,(39k) but if anyone is seriously intersted let me know. :)
To your question Ben, I would have thought CAMS cage and logbooked, but I cant be sure. That said, from what I remember, if you have a CAMS certified cage, the next step to logbook the car isnt much more than filling out a form and getting it inspected by a CAMS srutineer.
Should be a piece of piss Ben as your cage is a very similar YT spec to the IX just need a scrutineer? to sign off on it.
Best bet is to give Herbie a call at the CAMS state office and he will point you in the right direction.
Getting a rego inspection was harder than getting the cage log booked (too many anal RWC stations), in the end Transport just pushed it through with out one!
Apparently there are proposed changes to ROPS spec in the pipeline now that are due to be put in place January 2012. (Think there was a CAMS bulletin recently) You will need to get your car logbooked by then if the cage is built to current specs or if you miss the date possibly find yourself having to mod the cage to make it comply.
There are no major changes for new cages from memory, mainly that you need 2 cross bars in the main hoop or rear legs, and changes so that FIA cages will be cams compliant.
All Chromoly cages will ned to be inspected/tested by a CAMS offical before log booking
CAMS has a whole new section up on the site about the changes.
Finally seem to have the ability to reply - woohoo!  Had all sorts of trouble with my iPad and this forum, but found a cool app that seems to work... Sort of...
So I wanted to stop this nefarious rumour The Woo is trying to spread .... It seems that merely enquiring after another's interest in an event constitutes entry (if only this were true).  Boy I had a lot of explaining to do to my husband (pool heaters)
The closest i will get to being at Classic Adelaide (or any other event in the foreseeable future)  is if Kel takes up my offer to be her groupie .... And even that's not looking so good right now - I hear I need to slay her other groupies to be considered at all, as she has set up a master chef / DWTS elimination style process
(now counter-rumoured, my work here is done)
Mel
Edited by datgirl
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
