Tarmac Rallying Perpetual Thread
By pester i mean throw my hat in the ring.
I know what you mean regarding the promo stuff. Did have my name on some "cool" jobs at the first wrc over this side of the country and got relegated to the command centre cause of sponsors.
The Octagon do have a great team, and sure, no harm in letting Stu (To1-100) know that you're keen to help too!
I've been fortunate enough to be able to be part of mobile crew a couple of times now, and thoroughly enjoyed it :)
So it's just over 3 week out from Targa High Country and my nav (aka Dad) has been stuck in a hospital bed for most of the last week.
Sorry to hear mate, I hope he is on the mend.
The one thing I can say is if you don't make it, Octagon are very accomodating in transferring your entry to future events. Don't know of many other organisations that do that.
That sucks! I hope he's on the mend?!?!
Thanks guys. No progress today, the doctors are still trying to run "tests" to work out what's up. Going to make the call next weekend. We talked today and i'm still going to try and run in the event so hopefully i can find a nav last minute if worse comes to worst.
Will keep the entry transfer in mind though!
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
