Perana V8, step aside...
are these kind of shenanigans still allowed in Targa?
Yep good thing's, we have a customer with one of these LHD and all, AASA rule's allowed him to fit an LS1 and 6 speed
wild looking set of alloy arm's under the back of the thing..
I spoke to the chap with the Scarab at Baskerville about 12 months ago, I was quiet interested in his lhd 280Z until he lifted the bonnet to reveal a pushrod engine were once lived an L block.
And speaking of chook cookers still for sale now with new turbo freedoms fit a D9 dozer sized turbo and cook your chooks faster
Last time I looked at these it didn't work as Scrarab wasn't connected to Datsun in any way.
There were a heap built from memory though.
What you need is a good rotary.
How many Alex seals you blow while typing that :P
Ahhh,
soo much rotor love. I'm keeping my mouth shut as I am sure any tough talk on rotors will only come back to bite me in the arse when it self destructs at a really inconvenient time. :)
For your amusement....
I for one hope it all goes well for you Blaise and that you take it to the Porsches!
THC.... who's going? I'm doing "00" again, and will be driving up there Thursday PM with Captain Fathom, primed for festivities :)
Cheers Woo,
i really hope it works out, but gut feel is I had a pretty lucky run with the evo and it was a robust, reliable fast car. I think I might be out of my depth with the Rotor, but I do like a challenge. :)
For anyone interested, am collecting the shell this week. In the background I have been chatting to some people in the know about the suspension. We got as crazy as looking to graft as much of an FD into it as we could, but I decided that was WAY beyond our capabilities. Have scaled back to not reinventing the wheel and doing a V8 supertaxi spec live axle rear end in it and updating the front end. Go as light as possible and try to get a strong reliable 350 odd hp turbo rotor for it..... dreaming I know. Reliable and rotor dont really belong in the same sentence:)
Really wish I was coming to THC. The missus and I had such an aweosme time last year and are both a bit sad we arent there this year. Best of luck to all those taking part. Wlll be living the dream vicariously following it on the internets.
Edited by Darkside
I'm keen to come up for a chin wag at some stage but not 100% sure I'll be able to do so.
If I can make it I'll see if I can drag MrRB20 up and we can have some prelim discussions on Euro 2012 Woo.
You're not in Melb for any length of time are you in case we can't make it?
A few old Datto Z cars including Jon Siddens will be there for THC, hope they can stick it up a few 'non ABS equipped' Porkers. Well maybe they might have a chance against the 'budget', under $200000, ones :thumbsup:
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
