Details on the caddy?
Found this but no details on the car, what's done to it and what made them want to Targa a Caddy?
http://www.targa.com...&team_id=236322
Edit: Hah! Check this out.
agr_targa-day-3-22-of-30.jpg?w=1024
" A bigger turbo is pumping 45psi of boost into the diesel engine, which is limited to 450nm of torque and puts around 130kw at the wheels through a limited slip diff. And what’s more, it’s lighter than the Golf it’s based on, too."
Edited by ActionDan
I don't doubt there's 45psi being pumped into that thing...the noise it makes is amazing :3some:
How happy would the cage builder have been too, look at all that room!
With Targa Adelaide out of the way our focus is now on Targa High Country on the second weekend in November. The course remains unchanged save for a 'new' stage before lunch on day 2 called Devils River which is 'Skyline' in reverse.
We will be there in the Evo with a few upgrades thanks to some extremely generous sponsors :yes: and while the fast and flowing day 1 doesn't really suit my pilot, she really comes into her own on day 2 where it gets a little more technical.
So who else are we going to see there?
We are booked in for High Country as well. Re-built car is due to be finished mid next week so looking forward to getting some shake downs in and make sure it is all ready.
I enjoyed having two cracks in a row at Skyline in 2011 but in reverse should be a bit of fun too.
See you guys out there!
I'll be there too with my trusty nav Fook, hopefully debuting the new DR30 Skyline? It's still a looong way from ready, so Melinda's GTR is the fall back option.
Quite excited really, first tarmac event in since Targa 09, and that one didn't end well..
Musttt...get...back....in....shed.....
Best of luck to all those actually racing.....to those hangers on showboating.....ahhh...I'm just jelly arse. Such a good event. Am soooo over spectating...
But such a long way from this.....
to this.....
Update big guy? Some pics? Something..... anything!!!!
After seeing some of the retro group A stuff at WTAC (nissan bluebird and 32 GTR) keen to see the DR30 out there. As Woo said, love to see some updates.
And good to hear the 34 is getting back out there.Such an awesome car.
And Woo, do you mind if I use that line?? :)
Cheers Woo,
and speaking of which (OT) my new favourite thing is once inside the heads, through the 8 knot zone and back into the open speed zone on the river, opening the taps (and the captains call) and passing other vessels who may have not cared about the 8 knot zone so much and come past us. Full trim....fulll noise...and heaps of air as we launch off their wake passing them. The missus questions whether its good for the boat.....I guess we will find out... Might have to get a go pro on board...... Highly amusing, although I am easily amused. :)
Hopefully is doesn't end up like this.....
http://youtu.be/AgXy0EcCcOQ
Edited by Darkside
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
