yeah I think its awesome to see more events to choose from without the cost and time of heading across bass straight. although there are already plenty of choices I Vic so its a shame NSW RMS won't close roads for these types of events.
I actually prefer multiple runs over a long hillclimb rather than different stages, also much easier logistically requiring less crews all over the countryside with jerry cans,
These sure are going to be some amazing events guys and its great to finally have announced these and hear your feedback.
The point is certainly taken regards calendering, but things aren't always as easy as they may seem.
Arguably, Australia's best driving roads are found up and down hills, mountains and ranges, and alpine regions provide the best of the best.
Due to a number of factors there is only a small window of time in which to operate alpine motorsport events and complications include:
- adverse cold weather due to unpredictable weather at such heights in the cool and cold months
- there are also various issues with running closed road motorsport events during summer, including soft alpine road surfaces which de-laminate with ease thanks to high-G loads of semi slick tyres
- high volumes of traffic on popular through roads such as Great Alpine Road during general and school holiday periods
- fire risk thanks to dry road side vegetation in the warmer months before the chill of winter creeps back
- general threat of Code Red fire danger periods which simply do not allow events to occur
- an already busy general motorsport calendar
When researching date options, popular opinion amongst those entrants traveling long distance was that bundling events closely was very much a positive and actually justified the cost and energy of traveling and freight cars from Western Australia, Queensland and even Tasmania.
Please free to ask any questions.
I'm in. Just flew back from a recce down there. It's going to be interesting trying the east coast loop in the traditional direction. Sideling would be mighty slippery in the wet and early morning.
They've cut out quite a few sections in favour of the South Hobart ones. Im kinda wishing they made it 7 days and they ran all of them :D
Anyway car is all ready besides an oil change. Have gone with 6 medium A050s which could be risky if its a completely dry event.
I'll try and post some daily updates this year for those stuck at home
It'll be good to do the Sideling the proper way again though I think the morning run will mean an 'unclench arse cheeks' note might be needed after the flying finish ;)
We're on the boat Friday week.
There needs to be an event on Bogong High Plains Rd between Mt Beauty and Falls Creek. I've been up and down there a number of times in the past always couple of months before winter. It's still ok weather and only the odd car or two on the road. The Great Alpine Rd is too old and shredded up imo.
soooo sau drinks?
  • Like 1
Ill see all you Nissan enthusiasts around te traps.
Service crew again this year with the les walkden rally team.
The new format will be interesting. I'm not to sure its heading down the right road thoe. Proof will be in the pudding.
Looking forward to poatina stu!
See you all there. Heading down Sunday arv, stepping into the Trophy Sweep car, so will be mingling up near the front. Home early for beers though :P
Very much looking forward to doing the traditional course again, albeit in a slightly altered, smoother layout. Sideling in the tradional direction is awesomesauce. Can't wait!
What aren't you sure of Damo?
Hey Liam good to see you are heading down, good luck!
And Damo and Ben, hope you have quiet weeks on the crew side....
Kel and Steve are not off to an awesome start, they blew something, probably a turbo at symonds plains today....long arvo ahead but at least they have a spare.
Hey Liam good to see you are heading down, good luck!And Damo and Ben, hope you have quiet weeks on the crew side....Kel and Steve are not off to an awesome start, they blew something, probably a turbo at symonds plains today....long arvo ahead but at least they have a spare.
Thanks Duncan. Car passed and ready to race. 4 stages tomorrow. The first three look to have easy base times so most should pass. Georgetown has a 3 min base time so will be a competitive stage for most.
Sounds like the jj crew are in for a busy night!
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
