They are pretty different. They are all about low down torque and corner speed compared to a skyline, chassis development has come a long way in 20 years. Over a stage the Subie would be faster I recon
Will be interesting to see how fast you are compared to the skyline. Still have all the creature comforts like air con and a radio?
Have to figure out how to recce the whole event on Fri, Saturday and Sunday afternoon while still getting the car past scruit and going to drivers briefing. Looked at hiring a gti golf but only allowed 400km per hire.. looks like 1800km in the patrol in 3 days
You with Adam Clarke?
No. Adam is a great mate and has sat beside me a couple of times in official roles. We will carry a couple things for him but I'm actually servicing for Closey.
Getting into the whole "Spirit" this year and taking the boat over and back from Melbourne. :)
You'll have great fun. I quite enjoy crewing....not us much as racing though
No Radio, but I have A/C
hmm well it looks like Liam's awesome run of reliability (luck?) has come to an end, some sort of diff problem last night and retirement today :(
Kel and Steve changed a gearbox after the symmons plains day and a kingpin bearing failed today but they've changed the upright and still going OK. 3rd in EM today.
Looks like Ben's running 2nd in GT4 in the dirty subbie just behind super sub Timmy also in a dirty subbie, good luck guys
I love Quinny's style.....what do you post up if you put your lambo up a bank? (and he blamed the bloody nissans and other rough cars ....)
  • Like 1
  • 1 month later...
So despite Mark Perry's commitment to "stability" in the regs, the latest change is to ban e85.
Not good for my wallet since I've just spent thousands on ECU, flex sensor, fuel lines, pumps etc so I could run it at targa, but I do think it's good for the sport to slow cars down.....faster cars = bigger crashes = sooner that we are not allowed to do this any more.
I think it's more to do with getting the early modern field away from the GT2/4 pace. It wasn't announced in the release, but the GT2/4 cars have all had more weight added to them across the board, I've got to put another 40kg in the Subie, Quinny needs to put 50kg in the Lambo.
The E85 ban has been on the cards for a while, it's just been a matter of when it will happen.
Hi guys, was wanting to pick your brains on suspension choices to suit bumpy mountain roads, i thought you targa guys would have some feedback on what works.
I'm considering MCA (Reds, maybe Golds), DMS (Street series or maybe the 50mm version) and Bilstein PSS9s, a lot of good feedback on the MCAs, as well as the custom valving/spring rates which can cater to the sort of driving i like (street/mountain roads over track)
Any feedback, experiences and budgets as my budget is between $2-4K for something that improve suppleness/road contact for bumpy roads, but also provides sharpness for turn-in feel.
  • 1 year later...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
