  giant said:
hehe... just emptied my swear jar into my kids piggy bank! he will be a rich little bugger in a few months!!!
fuc oath... :O ooops. swear jar.
Just spoke to my Dutton co-pilot (Blaise) who just returned from that pesky bit of tarmac otherwise known as the Nurburgring. And it seems he' suffering from the same problem as I had after going there in now wanting to step up to tarmac rallies in order to try and see if he can replicate the experience he got over there.
He wants to go back to his roots when we first met and was driving an imported WRX STi RA, but this time look at building a 22b replica as a tarmac car which should be sweet. It'll probably take him a good 12 months or more to get the project together but it will be tops to have him along playing in the future too (and good if I can get 12 months or so experience up on him to start with! LOL).
Dunc, hopefully there'll be at least four there, Quinny has a couple now too :) Well done Kel, hopefully she'll have a ball! :)
Snowy, Melinda Both is rebuilding her RA to a 22B replica as well, her and Paul may be of some use in getting some deals on multi buys of things like the aftermarket wide guards etc? PM me if you want her number mate.
I saw a genuine 22B on TAU in Japan for 22K about three months ago. I had a real hard think about it, but had a bit on cash-wise that week so couldn't stretch... would have been cool though.
Based on current indications there should be atleast nine or ten R35s at Targa next year.
So what are you going to have to have to be different then?
TAU = japanese car exporter. some widely differing opinions on the quality of the cars they sell. they wholesale to a lot of caryards and importers in aus.
you can certainly pick up a 22B in japan quite cheaply, no need to buy it off TAU either. :happy:
Yeah there's 3 on carales for +$100K.
His plan wasn't to buy an actual 22b but to build a replica from a cheap base but heck if he can get a genuine one at a stupid price I'm sure he'd consider it (although it'd be a shame to bugger a genuine one up with a cage etc).
I will keep an eye out at auctions. they are no where near as rare in japan as they are here. I've seen quite a few come up over the years and that was without actually looking for any!
you can also get a late model STI Type C or RA or whatever pretty damn cheap to import for race use.
Baron, i will bring the oxy, you bring the beer. I think its time we prep the S13 and show that intestinal fortitude mixed with the right amount of stupidity and my "nah mate she's flat...i have a perfectly matched set of buffed tyres so she will hold" navigating will have ..... ....people visiting us in hospital. :happy: Its up to us to bring SAU together and make our hospital waiting room the socialable meeting point of tarmac rallies :D
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
