Word has it, Pete, Timmeh and crew will attempt to run the MBS in early Dec despite THC being no more than 4 weeks prior...
Discuss :blink:
I just received an expression of interest email for Mt Buller sprint stating that if 60 entries are submitted it will go ahead.
Yeah, will definately go ahead with 60 entries but with only 80 odd last year with no Targa competition you would have to imagine they wont get there :D
Tour hey Snowy...in what this time? 36 or 50? :blink:
Edited by rexdan
PP would be well wicked.
If the costs worked out close to what you alluded to, I'd be a starter!
Getting a heads up soon... RORO freight v container etc. You being so close to a port would help too. Will forward e-mail when I get across it
TT
Yeah, will definately go ahead with 60 entries but with only 80 odd last year with no Targa competition you would have to imagine they wont get there ;)
Tour hey Snowy...in what this time? 36 or 50? :D
Oi Positive thinking please!!! :(
Some of us dont fit the class so this is our option...
So fingers crossed it does get atleast 60 entries cause im dying to go rallying and need the practice! :) I look forward to these events
Oi Positive thinking please!!! :P
So fingers crossed it does get atleast 60 entries cause im dying to go rallying and need the practice! :no: I look forward to these events
Don't get me wrong, I'd love to see it go ahead as much as anyone else if only to hear 'Kermit' the 32 launch ;)
However, THC will no doubt take some previous competitors out of the mix, though I do know of someone seriously considering leaving their car in Vic for the 4 weeks so they can enter both!
Don't get me wrong, I'd love to see it go ahead as much as anyone else if only to hear 'Kermit' the 32 launch :down:
oh lol you've named the GTR....Kermit!!! :)
Just doesn't seem fair to not have the first in best dressed policy...
So hope Mt Buller goes ahead so we still get to go Rallying!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
