I just put a magic windscreen in my car. Be interested to know details of other places to get them though as my current source (YT) only had the one and I wasn't able to find any other local sources.
In other news I got some THC stage details yesterday. Apparently Barwite looks like fun as its nothing but 9's + 10's for the first 2.5kms! I really need to get out there and have a look at the roads.
I have been told by JA that if you are going to recce Mt Buller tell the base office that this is what you are doing and they might waiver the $35 entry fee.
Magic Screen? Heated?
TT
I'll be interested to see how you like the heater. I asked some people about them when I started my car, and some hate looking through them, and some don't see them. I decided to save monies, and kept the heaterbox in my car for the sake of 4-5kg
Actually that was me. The car wiggled a tiny little bit - mainly through the steering wheel - when we hit some standing water and I wasn't expecting it - but at 200km/hr it gave me a minor heart attack!
In what way Jess?
I'm just hangin' to get back in the seat :blink:
Its been so long since I have been in a seat :P Havent been on that side since May :(
Do you find it takes a bit to get into the groove??
Im probably just being paronoid but have always been a bit of a stresser and being in another new seat can be a bit overwhelming at first just getting up to speed with the new driver I guess...
Im probably just being weird like usual LOL
Hahaha, it can be difficult to get in the groove, but I find that recce gets the bugs out and goes a long way to readying towards actual competition.
I suppose it can be daunting being alongside another 'new' driver, but again...as you know...recce helps!
I wish I could spend the time to do recce...I guess its my own fault aswell...But no driver I have sat next to so far as been in the "main game" so to speak and that serious...So I fly in Nav and Fly out again...
I would love to learn to write my own notes and get that much time off but with my motorsport schedule time off is limited from work as I do so many other events...
Ok will stop being a princess and suck it up... :cool:
Just would like more frequent events through out the year to stay ontop of the nerves....
Just venting :P its been awhile..LOL I am excited tho love MT Buller area its so lush and adventerous!!!! :blink::P:(
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
