For those that are looking to be reasonably organised and have as much info with them as possible, the individual stage maps have been posted on the THC website...these include the MANSFIELD stage map (finally!).
Don't know about everyone else, but with only 4 weeks to go I'm getting a little edgy... :down: Team Emo FTW!
THC Individual Stage Maps
So what navigation equipment are people using in their recce cars? I don't really feel like buying another terratrip just for the recce/can't be bothered swapping it from the GTR and back before the event so that's out.
Do many people take down distances to help get back on notes if you fall off or to mark certain corners/cautions? Most of the notes that dad and i are going to take shouldn't need distances however they would be helpful on the stages where you have to turn onto a different road (though these will be marked in the course notes/road book so is there much point?).
Does anyone use their odo's trip meter for an approx distance? i.e. length of straight before next corner.
Other option i was thinking of is going over a topo map/google maps and write down the distances for the cautions that way.
Dad and I are heading down for a recce of the THC course next weekend. I'm getting rather excited!! :down:
We just get around using the odometer in the recce car (transport stages)
Most don't use any Terratrip in recce cars, and it's not needed unless you're planning on writing your own notes, and even then it's marginal.
I typically like to mark kilometre distances on the side of the notes, mainly so the nav can tell the finish officials where/if they saw a car off, cross referencing with the officials info.
It's also good if the nav makes a note on the notes just to confirm they're on the right spot, any obvious landmarks like a big fence, or yellow sign, or dead tree, that kind of thing. The nav doesn't call it to the driver, it's simply confirmation that you are where you think you are..... and if you have a few of those landmarks throughout your pace notes, it really makes it much quicker and easier to get back on the notes if you happen to fall off.
Hope that helps :down:
Hope you enjoy yourselves too!
For the new car I've done away with the Terratrip and got a Garmin Zumo.
Has a nice little Odometer screen + can transfer easy between cars + plays music through an SD card slot which is tops since I no longer have any radio or anything!
It's quite cool really.
I Have a Tomtom and run a 3rd party program called TripMaster which is basically like a terratrip where you can have total distance + interval/speed etc.
I usually put the GPS coordinates for the start of a stage so we can get a pretty good idea of where we are going from that plus using the roadbook (although use the roadbook as your primary route as GPS may take you the fastest way but you might end up at a road block due to it taking you backwards up a stage!
But to be honest I don't really use a terratrip during an event as get a fairly good idea where your going during recce, its there and rolling over/being zero'd but i don't rely on it.
In stage i zero it at the start, but rarely look at it during the stage, unless i get asked how far to go, or mark a car off etc
Wouldn't stress too much if you get lost, plenty of time to get to stages. stop and wait for the next competitor and follow them. Lol!
If you do spend time looking at the TerraTrip during a stage, you run a huge risk of falling off notes.
During stage its really only used as a reference for oil down/car off/dead roo on road, that kind of thing, but having to look at it and count down to warn the driver of something is asking to fall off notes.
That's why i think it preferable to roughly mark the distance of whatever the issue is in stage On the notes, and you cannot do that without kilometre markers on the notes.
Thanks for the input guys :banana: don't think we will stress to much about the distances for next weekend.
Taking down the HD windscreen mounted cam so should hopefully be able to play back the route with the notes and note down any landmarks that we miss when in the car. Hopefully this way it will feel like i have driven the course more than 2-3 times...
Cars all ready now, new pads, semis on and ready, oil change, rad flush ohhh and a fresh dyno tune :D
So Im guessing the PMS 25 has been given the flick since Longhurst and that other bloke aren't in the line up.
But what of the Lambo's at the bottom, I hear weeksey is having a tearie cos his car isn't elligible (possible legal case), and whites are happy to do whatever to make theirs elligible?
Nah was chattin to YT the other day and he said he's more than happy to wind the spec back to comply with whatever the rules dictate.
Funny thing is, Lambo WILL actually sell you an identical one to his, dog box the lot, for you to drive as your daily, if you were that way inclined :)
would have have anything to do with white hot being a lambo dealer?
Lol maybe.... But, doesn't change the fact he welcomes returning to a H pattern. And Weeks' problem is many parts on his just simply aren't homologated Lambo parts but rather one offs.... whinge all ya like I say, but you can't make your own replacement homologated bits! Lol
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
