I want to know where these fast stages are! Sure there's some quick sections but every stage has it's slow to medium speed section to balance it out. Everyone is in with a crack...or are we smoking it instead??!! :)
I seem to remember that little 944 cleaing up the EM day 4-5 of Targa this year.
They won't have the benefit of 2 brand new tyres to help clear the puddles that they had then though.
And Dan is right - there are some really fast BITS but overall this course is twisty twisty. I've said before in the right hands I reckon an EMO could win Modern in this event and I can't see it being any different in EMod.
We only front to reared anyway, so no advantages.
Im just excited to use some new roads, and ones ive NEVER seen before!
It's going to be good fun. A couple of weeks out now and I'm starting to get excited :D
When are you heading over Timmy? And where are you staying - Top or Bottom?
I fly in tuesday morning (Cup day damn it!), staying at the top I think.
I actually feel really unorganised, all my gear is still filthy from the gravel season, haven't even looked at notes yet.
Wouldn't even know if the car has an engine in it lol!
I'm pumped up for 'BLUEGTR" to have a good run!
I hear the lad is quick!
Thanks Ben!! Just hoping for a good run this time in my own car.
Also got your number of Stu so might give you a buzz tomorrow about 4wd.
Although it's yet to be kitted out with it's full event livery and warning systems, the Just Jap Racing, Targa High Country R35 Zero Car is getting it's final prep for the event.
Steve from Just Jap is kindly handed over the keys to Targa Tasmania regulars David Ayers and Robbie Bolton (Nismo 400R) to blaze a trail for the competition cars at the 5-7 November event.
Fitted with almost the entire Just Jap R35 parts catalog, this is one Zero car that is sure get the spectators attention!
Emo's For The Win!
I kinda feel dirty saying that but hey its the truth. More power would be nice though.
Who is this imposter.... :P
Hahahah
I've already told ya I'll be a bit lighter than at Targa :) Should make up for our power figure!
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
