So is TT even on for you guys now Timmy? It'd be a big call to fork out the $$$ required given the cars recent history.
And yes YT did an awesome job. YT in the HQ v Glenney in the VC v Weeks the VW will be awesome if it goes ahead at Adelaide.
Well he thinks its fixable, I don't... Its now overheated good and proper about 6/7 times with the new engine, its an all alloy motor and plugs look like it was running lean.
It was showing some signs of headgasket, but not 100%. Not milky oil, but it was bubbling from the radiator and the coolant smelt fumey, so I reckon cracked water jacket in exhaust port.
Alloy doesn't like that sorta heat and the old engine was a testament to that.
I have asked for an answer by the end of the week so I can look elsewhere if need be.
Not looking good though, and I cannot afford to keep wasting time away from work for DNF's.
On the positive side YT was AMAZING where I spectated Saturday/Sunday, drifting all the way around the spectator point on Hellyer. You would never think it was a Monaro the way he drove the thing!
Gotta laugh though, it was so short notice getting the Monaro organised and a navigator arranged that at the first service Hodgo was running around asking if anyone had a spare Roadbook or Pacenotes! Lol!
The other really impressive car was the Todd/Tighe Perana, that thing sounded so good going up Stowport Rd (think i have vid). Shame they missed the first stage cos the bloody thing wouldn't start, reckon they would have been up there for sure.
Not entirely sure, he stopped on Hellyer Gorge with a mechanical and had requested a tow truck, but when we drove from Warratah service back through Hellyer he had got it going and made it to Savage. Heard various reports that he had stopped again on Savage, but also heard he had gone off road so not too sure.
Alot of crashes thats for sure this weekend!
So Snowie...its been restored and now the asking price has tripled....shoudl have bought it and been one of the cool kids when it was going cheap
http://cars2.ebay.com.au/1993-Lotus-Esprit-GT300-GT2-LeMans-Race-Car_W0QQcmdZViewItemQQitemZ270672966729
http://forsale.classicandperformancecar.com/detail.aspx?ad=19893&d=1627
hell yeah you should ahve bought it!!!!!! you know esprit is just about my favourite car (shame the road going ones are pretty ordinary in the power stakes). where was I when this came up, I would have impersonated you and signed you up before you knew what happened. for your own good of course....
Gearbox failure I'm told, could only get 1st and maybe 6th ?
i was talking to 1 of the guy's from LWR, who help out Quinny
and it had cylinder's 1-3-5, but 2-4-6 must have gotten bored,
because they just disappeared...
but this was my favorite bit of new's for the day
http://www.sportcom....art=0&Itemid=59
go the Dutchy's, got to see talent get the gig over celebrity
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
