Mostly cosmetic, bit now we are running E85 unrestricted, have to fit new injectors, surge tank etc as well as change it all over to Tarmac. Bodywork is done on it, suspension has been changed. plus it needs a tune too now :-(
The Longford Revival Festival site is coming along well... even after all the rain last week the grounds are good and the Flying Mile nice and clean now... ready for some max speed runs from the racers and exotics both old and new!!
Edited by t01-100
Yeh don't care about that since I can't go. More importantly whats the go with Day 2?
Looking forward to the Longford Festival, should be a great lead up to targa week.
Massive thanks to Stuart for getting the Radcam's down to us the night before the safari, pretty sure you must have raced down there as soon as we messaged you :-)
I'm arriving in Lonnie saturday. Will have the customary piss up at the Olde Tudor saturday arv/evening.... and this time, Dicky Johnson is joining us :)
we finally have a good 999 car.... eddie decided using other people's crap was too hard so he purchased quite a nice Emo 8, all prepped up :)
Hopefully the top of Rossarden has been washed away. I shit myself going over there!! LOL
I'm on the ferry tonight ready to get into it.
Well I haven't been out yet for a look, but I saw on the news last week the train bridge you pass under at the end of Rossarden stage just before turning back on the highway (where every one services) and the water was up to the bottom of that bridge!
Ooh Yay! Will be good to see ya! No doubt ill be trying to squeeze 5 days recce into 3 so maybe not till the welcome party.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
