Email sent Greg ;)
Mel texted me asking if I was doing it, and she said she had plans to.... maybe you should talk to her :P
The dirt looks like a lot of fun (to drive), but it's the pulling apart and fixing the grubby things I don't rate :)
^^^^ Thats the only lack of appeal to me of the dirt. I really like the idea of sliding around on a budget, but the ongoing servicing, repairs and maintenance, even if you run a clean rally and dont touch anything could get on my nerves abit. That said, i havent done it so am only speculating.
tarmac, as long as you dont crash, quick wash, fresh fluids etc, and away you go..
Hmmmm.. group C RX 7 turbo..... Anyone who will pay sensible money (see what I have done there Woo :) ) want to buy a Targa Prepped TME? Is CAMS logbooked so will be good to go for next year.
Does this also mean that the other CAMS rallies will fall in line regs wise with the Octogon rules (Targa West, Rally Tas, Mt Stuart etc)??
Be good if there was just one set of rules thats for sure.
+1, good call
I would say its only a matter of time. The CAMS regs are one reason I cant be arsed respeccing my car and running at Targa West.... the shite roads and repeated stages is probably the other. :)
CAMS have already relaxed their rules on exhausts. I expect injectors and fuel pumps etc will come soon to embrace the E85 phenomena. Then its just the silly ones like adjustable strut tops etc to get rid of and you are just about there.
All this talk of new projects has tempted me to put the EMO on the market. I am asking crack pipe money for it on MY105,(39k) but if anyone is seriously intersted let me know. :)
To your question Ben, I would have thought CAMS cage and logbooked, but I cant be sure. That said, from what I remember, if you have a CAMS certified cage, the next step to logbook the car isnt much more than filling out a form and getting it inspected by a CAMS srutineer.
Should be a piece of piss Ben as your cage is a very similar YT spec to the IX just need a scrutineer? to sign off on it.
Best bet is to give Herbie a call at the CAMS state office and he will point you in the right direction.
Getting a rego inspection was harder than getting the cage log booked (too many anal RWC stations), in the end Transport just pushed it through with out one!
Apparently there are proposed changes to ROPS spec in the pipeline now that are due to be put in place January 2012. (Think there was a CAMS bulletin recently) You will need to get your car logbooked by then if the cage is built to current specs or if you miss the date possibly find yourself having to mod the cage to make it comply.
There are no major changes for new cages from memory, mainly that you need 2 cross bars in the main hoop or rear legs, and changes so that FIA cages will be cams compliant.
All Chromoly cages will ned to be inspected/tested by a CAMS offical before log booking
CAMS has a whole new section up on the site about the changes.
Finally seem to have the ability to reply - woohoo!  Had all sorts of trouble with my iPad and this forum, but found a cool app that seems to work... Sort of...
So I wanted to stop this nefarious rumour The Woo is trying to spread .... It seems that merely enquiring after another's interest in an event constitutes entry (if only this were true).  Boy I had a lot of explaining to do to my husband (pool heaters)
The closest i will get to being at Classic Adelaide (or any other event in the foreseeable future)  is if Kel takes up my offer to be her groupie .... And even that's not looking so good right now - I hear I need to slay her other groupies to be considered at all, as she has set up a master chef / DWTS elimination style process
(now counter-rumoured, my work here is done)
Mel
Edited by datgirl
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
