This thread has been a consistent delivery of lols, very impressed :D
Thinking i might start to Nav, i don't earn the bucks like you blokes, be a fun way to get into it. Plus I'm a good passenger, especially on dirt roads in WRXs ha ha.
I started as a nav for a mate, we had a ball until family stepped in the way. Then I navved for another dude, then he quite it too. I couldn't turn my back on it, so I decided to turn tricks on weekends to help fund it. Kind of painful having to turn Benson away all the time, I told him I don't know how many times that I don't roll that way but he's insistent. Maybe he just sees me as a challenge?
Just one... you're in a class of your own Woo!!
Poof. Aren't you still overseas or somethin? If not, GO BACK!
Treat 'em mean keep 'em keen?
Yes mate, back and full steam into it... big targa season ahead and plenty of teams doing work in the off season and everyone beating on the door.
White Hot, Supaloc, VIP, Just Jap and Yellow Racing to name only a few have all have plenty of work underway.
More new bits arrivng for the RX-7 too, and confirmed my nav while I was away for Rally Tas 2012 too!
Your Nav? Hang on! What have I missed? Can you drives withs gears?
Supaloc, new V12 thing innit? Reading the tests on them, they sound absolutely amazing, a huge leap forward from the Murci, the last actual Italian designed one.
Was speaking to Baldrick on the weekend, and he recons that YT has a new Gallardo, and weeks is running Murci and not the Aventadore. But it's from Baldrick so they could still rock up in anything.
Lolz
But, Big John did get a new Gallardo it turned up during targa this year.
Aventadore, maybe its a hybrid Commoghini?
Yellow Racing - ZR1?? :)
They went to the States recently and track tested a whole bunch of stuff from Ferrari to Vettes..... not sure what the preference was. I do recall one of them telling me that the Z06 was more suitable to racing than the ZR1. Unsure why though.
Same for Z06 though. They actually took a car to my mate across the road who does lots of cages (and many of theirs prior), he suggested that the entire car would need to come apart to do it properly (basically make a self supporting steel cage in and undr the car), but they decided to take it away and have it done elsewhere. Not sure of the outcome.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
