My requested for a 400R build with a big fark orf BW9180 turbo has already been declined :(
Seems the single turbo conversion is ok'd on a case by case situation.
The 13B twin turbo RX7's are allowed a control turbo and manifold, good for 300 KillerWasps on E85.... that'd be fun :D
^^^ Was just chatting to Snowy. We figured it might have been around the RX7's as the twin sequentials on them are a bit ghey apparently.. ie unreliable. Could make an FD a pretty good thing for EM I reckon. Who do we know who has an FD?? :)
An bris, thats twice this morning I have been bashed by a big brown monster with a stick... I'll try it neat next time chased with an invalid. :)
Looks like benson wanted to make his rental more compdeditive :P
I thought the 102 would be for the na cars that don't get a power gain from e85 (lambos), I recon the rx8 will still run e85, and still be unreliable
Lambo's can't run 102 though (and they have also been banned from running E85 now. Well - the R35's have. And I'm pretty sure that 2 of the podium getters were running E85 last year as well).
Its only LMS and MS cars that can run either Elf or E85. SS are limited to 98RON.
But I'd be willing to bet a can of coke that Mazda will run the Elf.
how long till a r31 gts-r becomes a classic?
LOL, yeh when are people going to run cool cars. By cool I mean old, unreliable, slow but loud cars. :whistling:
If someone wants to build a Sierra I know the perfect car to build up as it already has all the good parts from either RS500, Grp A or aftermarket :)
Serial, I reckon the 31 rear suspension setup is just too shit to be any good on a Tarmac rally. On circuits you can set them up stiff to alleviate the appalling camber changes, but a rally car, esp a two wheel drive one, really needs to be pretty supple.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
