Our car is almost alive again. it's all aligned and engine is back in. And the Guards and Bar will probably be respayed in the new year. Also got a 80mm Trust Ti-R coming, and a Power FC Pro.
Hey quick question for all you rally pro's - I got my pace notes for Wrest Point yesterday (very exciting!)
But I'd just like a quick definition explination if I can.
I know /o = over crest and /oo = over flat crest. But what exactly is a flat crest? Does that mean it only has an up (so flat on top rather than an up then down) or does it mean its a crest you take flat out?
Hey Mr Trickle, dont you take every blind corner with the foot flat! :banana:
Yeah well blind corners are no problems. There's nothing a handbrake and some opposite lock can't fix. But crests are a whole new ball game!
LOL @ Roy you tossa :banana:
I don't know how to get the proper graphics used on here but I'll try.
OK, /o is read over crest, it's normally adjacent to something like an /o into or R4/o, whatever.
oo/ is read and I like read as striaght over crest, flat crest can be a little dangerous and misleading. Some guys say "flat over crest" but that can end in tears.
Typically during recce we look at it, and if it's safe, then we say "flat over crest", and make a note on the notes like, FLAT, GO!!!, and the Nav will say again, "yes it's flat" if he has time.
For instance on say, South Rianna stage, there's some long straits with blind crests, and they are indeed flat in 5th (with a little lift to settle the car for landing), but later in the stage there's oo/ then (then being about 100m) into L3, so you don't want to be flat. Thats the time the nav needs to be well aware and reading those notes together, and they should be underlined to ensure that they are.
I hope thats not confusing, I have trouble explaining things without my hands! lolol
Edit: And it doesn't reference the shape of the crest, ie, yump or jump, it's purely the direction of the road.
Edited by Marlin
The tulips you'll learn to respect most are (well for me anyway) are the "ON C", ie, a grading and direction on a crest, where the middle of the corner is close to the peak of the crest.
Thats where alot of slower guys tuck right into and hug the corner to be safe, only to drag gravel onto the fast line, all for you to come up and onto the crest with a bit on, to find lovely marbles there trying to wash out the car..... I'm always extra careful on those, rerally try to apex those ones late so you have a little extra room on the back side of the crest.
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
