With a Z31 couldn't you run it as a 200ZR with an RB20 (silvertop conversion with redtop covers if you have too), thus bringing the costs back to 32 levels but with an earlier build date ...
Edited by MacGillaZ
831 Early Modern Jeff Beable Nerida Beable 8 LMS C 2000 Nissan Skyline GT-R V-Spec N1
847 Early Modern Liam Howarth Larry Howarth 8 LMS C 1995 Nissan Skyline GT- R V-Spec
Looks like two mainlander SAU'ers to me
Progress for us is coming along, tech adviser from Renault UK was in over the weekend :P . Pogo's and extra wheels arrive end of this week.
Waiting to see if I am actually going to get a new race suit out of the french outfit....
How goes Savman's progress???
So Tuggah isnt far away now. No news on who is actually running from SAU? Seems only the Tassie lads are running
That would be Dad and I. Car's all set to go and with 8 fresh A050 Ms as of last weekend. Flying down next weekend (30th - 1st) for recee, hopefully the notes arrive before then! Fair to say i'm f'ing excited for it!
I'm hoping to make it down to Hobart for a beer!
:cheers:
Me too!
If I can swing it I'm coming down to fish a tournament with Mozz and the lads on the Double Black on Friday, Saturday, Sunday, and see everyone at the Tugga Bar on Sunday night!
Only thing holding me back from booking the flights is I stupidly signed contracts for a bloody property settlement on the following monday! Grrrrr, IDIOT!
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
