what are your main and lift pumps? If you think about it, when you return fuel to the tank you have 2 pumps in serial...the lower flow one must determine the overall flow.
Duncan, thanks for clarifying that in the earlier post. I knew I must have been missing something :unsure: and this is exactly the info I'm looking for BEFORE I hook everything up. :cheers:
That said, our intank would be 255lts/hr and the main pump 300lts/hr, not a huge difference and theoretically so long as the intank is not being a lazy bitch it should supply enough to keep up with the main. Our pissy little 2.0 doesn't drink a great deal at any time so shouldn't have too much of a drama.
Oh, and here's our quickest run from Saturday, my third competitive rally stage and quick enough for third place until the engine said enough.
GTR lift pump and 044 pressure pump
A few points regarding fuel systems.
Fuel coolers are factory fitted to almost all late model turbo diesel cars due to the high fuel pressure/ friction heating. They are definatly a good option on a race car.
I have seen a few examples where people can notice a drop in power after driving for a while and then apon closer inspectin the surge tank is very hot to touch.
Duncan. Most fuel pumps are rated at a set pressure and voltage. If the lift pump is un regulated it should be able to flow more volume than if it was regulated so a lower volume pump should keep up to the pressure pump. That is the theory I have worked off. I only ever use standard skyline pumps to lift to a single 044. They seem to do the trick.
Once again if the lift pump is able to flow a similar volume to the pressure pump than returning the fuel rail to the tank rather than the swirl pot won't be such a big drama. This is why Ben and I did his tank that way. When the hot fuel is returned it goes into a big heat sink. ( fuel tank ) rather than the swirl pot. He's done 2 Targas with no fuel heating or surging issues. I'm not saying this is how it should be do just that we do it this way and have had no ill effects. If it was a single lift pump goin to 2 pressure pumps in high hp applications than the return has to go to the swirl pot but for 300kw or under rally cars doesn't seem to be a problem.
Re engines leaning out. The best method period is individual exhaust gas temp sensors. They are a bit of a pain and fairly expensive but they also make tuning easier. I've only ever had anything to do with the racepac version which is around 800$ for a 4 cylinder. If its tied into a racepac dash it will warn you of one cylinder is out of range compared to the others. Far better than fuel pressure unless that is set up with rpm parameters.
Mine and bens are similar size around the 1.5 - 2l mark. No point having a massive swirl pot for the fuel to slosh around in.
And yes plumbing wise that's how we have done it. I mean you are free to consult your own expert but we both run 300kw cars with Bosch pumps and oem lift pumps and they seem to work.
Also don't forget to wire the pumps in via a decent supply feed and relay. I also highly recommend wiring the supply via a re-setable circuit braker somewhere in arms reach of the driver. All circuit cars I do have these and as far as Tarmac rally cars if you happen to have an issue there isn't always a fuse handy.
Just going off my personal experience
^^^ Some great info there.
Are you guys running E85? Am looking to run single lift to surge tank to dual 044 to feed the chook cooker. Plan was to do the standard plumb the return line into the surge tank to ensure it stays full, but preferenec would be to avoid fuel warming issues.
If your running twin pressure pumps you will suck the surge tank dry. You would be best to put a cooler in the return line to the surge tank.
Another good option that a lot of cars are taking up down here, is a low level light for the surge tank. It's good protection against a lift pump failure.
One thing that has kept me awake at night the last few nights has been flow rates of two different pumps.
My plan is to us a 255lph in tank pump (lift) to service the swirl pot and a 300lph external from pot to engine so my query is, do I run these off the same trigger wire from the ECU so they effectively run the same voltage at the same time or do I wire the lift to have a constant voltage and only trigger the external from the ECU?
I'm guessing the pumps will flow different rates at the same voltage which leaves the issue of the external draining the swirl at a greater rate than the lift can supply it.
So many variables to think of before setting this up! :wacko:
I think taking worst case, not a safe option - and against the general requirements, assuming Cams sanction.
Post # 5405 pretty well explains why running the pressure pump against the reg and line restriction with a lesser capacity lift won't be an issue. At the 12hr a few years back, before they went all GT, did find a significant increase in fuel temp even dumping back into a 100 litre tank, fuel pump probably over-specced.
All the kool kid categories run cable (if not direct) drive fuel pumps nowadays!
Dan you use the original fuel pump feed to trigger a relay for each pump. This way both pumps behave like they should. They will prime with the key and also turn off with the engine. Wiring them direct ( not switched via the ecu) is vey dangerous under crash situation.
Thanks Damo, exactly what I was wondering :cheers:
Dan, Whilst the lift pump will only be supplying 255lp/h, and the main taking 300lp/h, there should not be an issue, as long as your engine doesn't need the full 300lp/h supply, as any left over from the injection system comes back to the surge tank and maintains it's level, essentially the main pump is resupplying the surge tank with 300lp/h minus the fuel taken by the engine.
Definitely do not wire the pumps directly!
  • 3 weeks later...
Stu was one of the few survivors of a plane crash in Burma yesterday... I don't know of anyone who has spoken to him directly but the news report says both he and his girlfriend Anna are OK.
http://www.abc.net.a...e-crash/4443714
Hopefully they are both well and going to be heading home safely soon.
  • 3 weeks later...
Happy new year all. Hope everyone had a good break. So what do we have planned for 2013??
At my end I am hoping to have this chook cooker hiding to nothing built by mid year in time to shake it down and if all goes well be at THC. Long road though as the chassis work has just started.
What is everyone else planning to get up to?
I've entered the little RB20 in Targa Tas again this year. I should have the engine back in it within the next couple of weeks. Hopfully then I should be able to do some decent testing for the first time in 3 years.
I'm heading down to Wrest Point in a couple of weeks to crew for the car Damo is navigating in.
    • This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
    • good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
    • Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me.   Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt.   Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension.
    • Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
    • I would strongly suggest using the correct tool. They are not expensive and make the job much easier and don't damage the lock ring. Google "fuel tank lock ring removal tool" to see what I'm talking about.
