I don't think cams test many RB20's. The bloke measured it, then turned round and asked "ahhh do you know what the stock stroke is meant to be?" (69.7). Stroke test is just a simple steel tube with a high and low marker. I think the more advanced volume test is done if there is a protest, but i've heard it's not very accurate.
You don't need a RB24 Roy.
Were you down in Bothwell with a big beard Dan?
Hahaha Ben, no that wasn't me...was stuck in Sydney watching on the web :verymad:
I've seen them come up with a stroke of 85mm on an Evo at High Country last year. After a few more tries they got 88 :yes:
The fact that they are checking should be enough to deter most that would otherwise push the boundries of legality. What went on in the past can only be left to the imagination :rolleyes: (testing has only been done in the past two years).
last one for the day, Woodsdale
Awesome bit of driving there Ben! and Damo's calls are spot on (especially the 'get the fark outta the way'). Nice little catch just after passing the first car, did damo shit then?
Damo grabbed for the roll cage just near where the horses are running around. It's the first time in 3 years I've seen him flinch, but it didn't stop him from being on the $$. Pressure was on that stage, and I think we ended up 3rd fastest outright on it.
Stellar bit of driving and navigation. Those shite roads!
Well done guys awesome work and great to see another 32 punching above it's expected division!!
Although everyone here should be following Crest Racecraft thus have already read the link the boys posted up this morning the following words from the "gentleman navigator" deserve to be repeated here, much congratulations!!
Barry Oliver;
Special mention should be made of the early modern competition winners Ben Manion and Damian Roach who not only won Early Modern in their 23-year-old Nissan GTS-t but finished an outstanding fifth in the overall standings only four minutes behind our Porsche. It was the drive of the event.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
