The theory and fix *should* have been tested in race one, however as Duncan pulled onto the track the boost went goodbye. As the blokes were tightening things up after the inspection of the thermostat, it seems some coolant/crap caused some slippage in the bay and a pipe didn't get as much love as needed. Yup, we'd blown an intercooler pipe.
After some afterhours tinkering (and more skin and blood being sacrificed to the car) we *think* it's sorted... touch wood.
:( After tinkering with Duncans car today. No one better tell me Z32's are hard to work on anymore. I HAVE COME TO THE CONCLUSION ALL 1990'S NISSANS ARE MADE EQUALLY DIFFICULT. :) .
What a dumb place to put a thermostat. Dont worry Neil. I am sure our burns will heal fast. :rofl:
I am sure it wont take long for the local IGA to replenish stock of distilled water after the run on stock they had today wiped it out. :)
Edited by Tektrader69
not cursed, just running hot. actually the race that I did get to start was a ball. all the other drivers were very sensible and courteous although a few of them were clearly very green on the race track.
and yes hislop's tyres were totally rooted by the end. that car is outrageously quick.
PI was good fun but I need more than 10 hot laps to get the hang of it.
and...interesting interpretation of the targa regs in some of those cars....really should have just been called sports sedans up the front of the grid.
quick? it was outrageous. 1.45.1 which according to the circuit times thread is almost a second quicker than Aaronr34's time which is the quickest on here.
This was the first lap of race 3. I got a good start but fried the clutch (not that I noticed until 3rd gear). Even so I was up from 24 to 14th before I gave up on the clutch and let the guys through...then limped around the rest of the race without the clutch (more practice needed, I can do it fine when I don't need to but I struggled this race)
BTW evos suck at getting off the line
You do know the cars are not based of Targa rules? The Targa classes are free for all, but the lap time dictates your class. The front runners cars are insane, Lawson's 200sxr is tuff.....but unreliable as buggery, he grenaded so many engines down here.
your poor clutch, you held it there for a while. Our clutch in the R33 can't handle more than 2-3 secs being revved...probably needs adjusting
Edited by sav man
hahah I do know now! But no I didn't realise until I started looking at the cars beside me in the garages lol.
Lawson's car is also amazing, standard capacity sr20, 1.46 around there. And the poor bastards changed a head overnight, then broke a diff about 2 laps later. I thought I was having top speed challenges but they were over 7500 in 5th with a 4.1 diff, I was only about 6000.
You thought it was running hot last weekend - just wait til this weekend by the looks of it! LOL
But that was your first real time there is a fast car doing fast times right Dunc? It's a different place once corners like 3 and Hayshed are no-longer an easy flat one hey! What was your best time in the end?
Oh - FYI Aaron has done 1.44's around there now. A few others have gone quicker still but not ones that could pass under propper Targa regs (Aaron could get his to pass pretty much ok though). But what were the tyre regs for the class? Was everyone on R Comps or on Slicks?
yeah everyone was on semis, although some cars got new ones for each of the 3 races. as usual budget talks. I was on dunlop dz03 for the first time too, and they are excellent, at least as good as re55s. I don't think top line current semis give away anything significant to same sized slicks.
one thing I saw once again....modern full weight cars put too much strain on semis and they simply fail. I saw stuffed dunlops, bridgestone, toyo and kumho tyres this weekend, none of them are up to the job of carrying heavy cars safely
I can't really call my car quick, turn 3 and the right hander into the hayshed were still both flat (although in 5th this time). I found the next turn left after hayshed and lukey heights very tricky but the rest pretty straight forward.
Best time was 1.53 and best potential lap based on 3x best sectors was 1.51. No doubt I was a couple of seconds off what the car was capable of, I really need time to learn tracks and lots of laps to go fast. Not like Pete who can set his fastest lap on the first lap, then gets slower every lap after :banana: I only had about 10 clean laps so hopefully will do a fair bit better next weekend. My guess is the car is good for a 1.49-1.48, about the same as eastern creek.
But I've never met a race track I don't like, PI is no exception. It definately has challenges, in particular judging the speed in the quick corners. I am sure I could carry 10 or maybe even 20 klm/h faster in turn 1 and 12 but I just didn't get the time to get the comfort with them, and if you run wide on the exit of either you are in the shit.
Les walkden wrote off his spec c wrx on the straight and went to hospital with a sore neck, so you can't under-estimate how much it will hurt if you mis-judge it.
snowcone did you work out your cooling problems? did the pwr setup help? or did the right one never arrive? I know mark's r34 runs the best water cooling he can get but still runs too hot too
Dunc - yeah I got it in the end and am running the same system as Mark (PWR Cross Flow).
The temps are MUCH improved. At Targa Tas for example the hottest I got the car was at the end of the Sideling and that was 81degs. No other stage got to 80 even. That's compared to 117degs I hit in half a stage at Wrest Point (before the wheel thankfully fell off and stopped me from destroying an engine! LOL)
That being said last Friday at Winton it was 37degs ambient and after 5 hot laps there the water was up to 95 and still climbing (so I went in after that) - but the car used to hit over 100degs there after 2 hot laps on a cold day. But that was the first time driving it in anger I'd had it above 85degs since putting the new radiator in. I totally rate it as a good thing.
Actually as a funny story on Saturday in the heat at DECA with all of the short bursts we do there and idling the water temps before my run on the short track were up to 94degs - but then at the end of my 60s run on the track they down to 84degs! LOL
But if you are keen on one of these things you need to make SURE you speak to the right person at PWR (Adam) and tripple re-iterate what you want! And even then chances are you'll need to modify it to get it to fit. LOL
Oh - and I'm sure they will tell you that you need one of their thermo's to run one. You don't. I still run the stock fan minus the shroud no problems.
IMO, if you did run the PWR thermo fan, you will find it even better Snowy. The give away is the DECA statement, proved that even a little more airflow, regardless of the engine working harder, massively reduced the temp. FYI, I run just one tiny little thermo fan with a PWR radiator.
Mine isn't a crossflow version, not do I run the oil cooler, but my engine is also a lowly RB20 and doesn't make the grunt that you guys do.
I have a hobs switch set at 91 degrees, and I'm alway astounded with how little time the fan spends running. It typically only cycles for five to ten seconds then is back at 85 or so. I have it set at 91 because I never wanted the fan to cycle in while the car is moving.
Timmy will attest to getting to the end of a stage and asking if it got, my reply was invariably "well it's nearly up to temp".
I only recall the fan coming on a few times when it had been stationary in a line up before a stage. Oil cooler yeh/no?
Best time was 1.53 and best potential lap based on 3x best sectors was 1.51. No doubt I was a couple of seconds off what the car was capable of, I really need time to learn tracks and lots of laps to go fast. Not like Pete who can set his fastest lap on the first lap, then gets slower every lap after I only had about 10 clean laps so hopefully will do a fair bit better next weekend. My guess is the car is good for a 1.49-1.48, about the same as eastern creek.
Good work Dunc. Interested about the semis failing....whats cars were they on and how did they fail? I have a fairly stock (no weight saving, 270-280atw) R33 GTR and never had issues with the semis. Also my pb at PI is 1:49 and I think a low 49...maybe...48 is possible if the wind is blowing the right way :( So I have no doubt your car is capable of achieving the same.
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
