Did you end up entering the tour Snowman?
Yep sure did. Am looking forwards to being up there and concentrating on the festivities side of things!
:blink:
BTW - apparently a new Tarmac Rally was announced yesterday in W.A.
Targa South West. Sounds promising although slightly confusing. Its running under CAMS but to AASA Targa regs or something!? LOL
yeah yeah benny, taspride's 'whoe whoe whoe' party, can't miss it mate. you're still coming down obviously? i've lined up all your fav boys to lick you down just before you're rolled in glitter!
mainlanders putting my drinking efforts to shame... bring it on! anyone in onyx at the end of tt this year would know my committment... and so does everyone that was out the front of wp at about 3:30am!
just imagine what you'd achieve if you took the skirt off before going out drinking Stu :)
wtf is happening with the temps at buller? currently 5o are they kidding?
http://www.weatherzone.com.au/vic/alpine-areas/mount-buller
wet fri/sat
dry sunday
either way max temp over the next 5 days is meant to be 15.
I can't believe all you skirts are skipping this event. Have any of you ever given it a run? any tips?
That's the thing about Buller - the weather is always going to be one end of the extremes.
But as for the event itself I'll give you a little tip.
Don't leave the road! It's a big drop....
:D
And definitely don't do a Heskin! LOL
:D
I was just reading the entry list, there is some pole smoker doing the Tour in an R35 lol! :D
wet fri/sat
dry sunday
One tip, clutch stabs! Oh, and DON'T bin it at the right hander on the concrete in the township.
Well I've put the thing up for sale so I figured I may as well try and have one more good time in it before it finds its way to a new happy home. :D
Well I use it as my daily right now and that's basically all I use it for. Generally if I want some fun I take the R34.
So I figured it's wasted in its current life. Plus I'm also coming to realise that with me doing all of these interstate rallies etc that I really should look at a tow car for the R34 rather than just driving it everywhere I go. So I've had to make the hard decision to let the R35 go unfortunately.
:D
cheap stag tow car or going something newer?(guessing you are with the 35's budget but worth a shot :P)
holy f**k just getting up here was an adventure. the stage will be a blast but tonights drive up was a shocker. wombats in the mist! couldnt see a bloody thing 5m in front in the fog (lucky kel had pace notes, no idea how she can read and make sense of those things in the dark). not to mention if we stopped the ute it never wold have got going again on that hill.
anyway here in 1 piece now, just need to sort out everything tommoz
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
