Wouldnt have happened if they had Crewman/Navigator/Stuntman/Fearless Brisby as a navigator.
Poor Snowy, best he could do was me at short notice after being dicked in the most significant way by someone that should know better! :) Got the car through Day 1 but the problems just could not be solved in the night....so Cascade Tour was the call for our Sunday. :)(
if jones doesn't get pinned, everyone is just going to drive through the middle of corners come Targa.
I'll be back with more later - but I'll add for now that there was NO mention in any paperwork or verbally in any drivers briefings about the white lines and no corner cutting for TWP this year.
Sorry I didn't get back to you snowman, didn't see the msg till friday and you already had the ever capable Brisby lined up. Sounds like he is a natural!
Well done everyone, been looking through the results and Newton, mate, well done!
Brisby, sounds like you did a great job at short notice, for what it's worth I can remember my first nav gig, it was a stress for sure! It gets much easier :action-smiley-069:
OMG...what a fantastic weekend. Newton is CRAZY and I love it! Just wait 'till he fully gets a handle on the pace notes :action-smiley-069:
We were only .5sec/km slower than the Early Mod winners - just a pity we had done 200k competitive :laugh:
Well done to Bris for the short notice call-up...by all accounts you're a natural :wub:
Credit to Snowplough for not following my calls on L4 when they were R3.5 :action-smiley-069: I thought i was doing ok until i watched the vids and he did well not to be confused by my talking...as thats what i did, talk us through the corners (often repeating the same call for an upcoming corner over and over which now i can see could have been rather confusing) rather then call the corners in advance.
But, we got through... and its depressing as my car isnt near as cool as any of the cars there :laugh:
Big Kudos to Bris from me for jumping in the car. He's are hard judge on himself but I think he did an awesome job and at no stage did any of his little mishaps put me off or put us in danger. Which is probably more than I can say given I chose to keep blazing on even though we knew there was a problem with something at the front of the car. Given what we know now we are both fairly lucky (again!) But I'd happily have the old boy jump in the car again anyday.
Well done to Norton and Dan too on a great first up Tarmac effort. Hopefully one day we can all have a good run and have a good ding dong.
Oh - and BRING ON TARGA HIGH COUNTRY in Nov!!! :action-smiley-069:
If they use the road from Whitfield to Mansfield for some of the THC stages it will be one cracker of an event :-)
Looking forward to you having another good trouble free run Snowy...you were only just off our time on Longley with the control arm broken :laugh:
Bring on the competition...next time were coming with softer tyres :action-smiley-069:
how did the E85 go? I'm thinking of setting up a E85 refil staiton 5-10km from the end of mt arrowsmith this year, as there's no way known a gtr will make it through 53km on a std tank (r32 and it's big tank aside).
anyone know what happened to Ayres? There wasn't any menchain of it on Rally Live.
Edited by sav man
As far as I know all cars got fuel tested. I was wrapped with that too since it was such a fark around having to get the EXACT right fitting which just so happened to be only available from one person in the country.
The funny thing was they rang me up with a panic after my sample because I'd had to use a jug full of boiling water to get my fitting onto my hose and as a consequence my fuel sample was full of water (both ends of the hose had closed ends) so they panicked my car was going to blow up! LOL
you tell them it's ok, just my water metonal injection :D
Expand Hollowneck?
A few were running VERY low on 98RON leading up to the stages. Topping up with just enough jungle juice to get through the stage, then splash and dash of 98 to get to the next stage and so on.. Someone cottoned onto this however and a fuel tester was manned at the end of some stages.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
