wats up SAU?
I dont know what happened to my other post but yeh im a noob.
Basically looking to see where most people in SA recommend getting their skyline serviced and maintenanced and how regularly most people do it.
Any info would be great. Im looking to make contacts with people who know their shit with skylines, who can inturn help me, cause i dont know much
peace
bryan
https://www.sau.com.au/forums/topic/228060-a-noob-looking-for-sa-skyline-info/
Best info would be to search. Youll find that 99% of the people will say Boostworks or Tilbrooks. regularly? well 5000k's of course, and the major at 100,000k's. If you want to make connections, make it out to as many SAU events as you can!
Yup as stated a search and you will find that most people will say Boostworx or Tilbrooks, but as there is another thread saying Tilbrooks are closing, that only leaves Boostworx.......
Also for parts you can see the twit above(ISC)......lol or head down to Japanese Motorsport or Jap Import Spares!!
i have to say jeff at the speed lab is awsome!! been to shaun once and he is great also!
my 2c!
check sig for jeffs number!
depending on where you are, i'd also recommend Road & Track in Enfield. Details are in my sig :thumbsup:
yo thanks for the help everyone ey, appreciate it
will check out those options for sure
Does anyone rate Car Toys for upgrades or people reckon they charge you too hard?
  • 1 month later...
boostworx took 13 months to put together my mates GTR, then it shat itself first week for them to only take another 3 months to fix that, and then try and charge him, saying it wasnt a warranty issue, when they built the motor. i used to go to tilbrooks, now i am thinking JMS cause ive heard brady is there????????? true or not?>
incorrect 2% say go to tilbrooks
made me lol Darren
depending on where you are, i'd also recommend Road & Track in Enfield. Details are in my sig :O
im up at st agnes i still go to boostworx
yes Brady is there
um yeah as per statements above my vote is for Boostworx
pitty boostworx is a bit of a drive for some people..... *cough* Northen suburbs...
ive heard good things about fours and more thats if you are from up north.
my 2c? never sent my car off to have performance upgrades done to it...... not yet anyway!
Boostworx +9999999. They have a very good reputation around Adelaide. Shaun and Troy do some awesome work and really know their stuff.
rb24det, I've never heard of a workshop taking 13 months to rebuild a RB26? What was the reason? A delay in parts? They rebuilt + blueprinted my mates VR4 and that only took 2 or 3 weeks.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
