Hi, I previously had a post stating i needed help identifying a misfire problem, most of you said its most likely the the coil packs and the plugs, it turns out after a dyno test that this proved to be the problem so thanks to all of you who replied and helped me out. The dyno run also told me i need to get a new fuel pump, and i was wondering if anyone could give me a heads up on what to buy (aka brand etc) and an approximate price. I was wondering if anyone knew cheap place to order some splitfire coil packs from, 520 delivered is the cheapest ive found so far.
https://www.sau.com.au/forums/topic/228159-r34-gtt-parts-help/
