  • Replies 51
Posted Images
A friend of abloke that works with me is a copper...he received a couple of months ago a brand new commo ss with all the toys you can put in them... and the flashing ligths hidde near where the rear speakers are so ,if you pass close to it you can,t realize what it is... :(
dont even get me started on spotting cops... last nyt on princess highway there was at least 10 cop cars within 100 metres.. got pulled over once and then again 50 metres down the road and got a defect for having a pod filter and an intercooler... looks lyk the eastlink or monash is best way to get to the city..
i sort of noticed this last night as well driving up to the city, on princess highway. Around 10 o'clockish there were way too many cops then usual, i thought it there was something suspicous happening.
each time i saw a cop there was a car pulled over or at one a cop did a u-turn and had its lights on drove behind me but then indicated last minute and pulled over some other guy ( i shiet my pants) prbly saw 6-8 cops just driving from westall road to crown -.-
A friend of abloke that works with me is a copper...he received a couple of months ago a brand new commo ss with all the toys you can put in them... and the flashing ligths hidde near where the rear speakers are so ,if you pass close to it you can,t realize what it is... :D
Only way you know they're cops is by the two extra aerials that the VE SS Commodores have added on the rear window, refer this pic I took a few months back of one...
Like you said though, full of toys inside, some things I reckon a standard car would be defected for :D
Edited by M34N
lol, vb as ur username..
i was in werribee 2 nyts ago, and seen a brand new ve ssv ute, with 4 antenas and a copper driving it..
bastards are in ute now lol.. wats next, mazda 2's, and hyundai excel's ffs..
its not like there invisable with all those antena's and shit..
Ive seen a cop going around in an undercover Baby Blue Toyota Camry. Anything is open now.
Massive Police blitz on fri/sat nights on princes h/way
atleast 15 Ve SS tmu marked/unmarked cars out
shitloads of people getting pulled over ..
got pulled over satday and mate got defected and he let me off stock car (sorta) for the win hahah
lol the hole campaign is a sham i tell ya..... they just use it as an excuse to be closer to the servo's so they can get there do-nuts quicker
I think this one is a lead up to the real sham, next week there will be a blitz in narre warren, will have a booze bus set up out side krispy kreme.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
