being an admin that has no part in any of this I will give you my advice. often when a member breaks the rules in some small way, rather than raise their warning level I will pm them, or post in the thread a friendly warning not to repeat that before. as such, most people will get 1 friendly warning, then it goes to official warnings etc. no, I don't want to try and interpret what other people have said, but if they said consider this your only warning, generally that means after this if you repeat the behavious you end up with official warnings, suspensions etc.
I would suggest just let it go. if you feel you're being singled out un-fairly by all means contact one of the admin team, but bear in mind they will almost always allow the various section mods to run their sections as they see fit. but at least they will impartially listen to your complaint (if you have one).
if a moderator has said
'consider this your only warning'
what does that mean?
my only warning before what?
I'd say it would be notice that you probably should have been banned already
However, the Admin/Mod at the time has thought better and given you, yet another (i believe), chance to do good on the forum before its cut abruptly short.
Cheers
Guest
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
