I was reading PF and came across a thread that said your nokia (only certain newer ones) can detect speed camera frequencies etc. Therefor letting you know of a multinova :)
Part of it seems like a sham, yet another part of it seems genuine. Like alot of things, ppl have backed up both sides of the argument.
Heres how it works.
http://www.adrian-9110-communicator.fsnet....a_9110_45x.html
Im sceptical, however im going multinova hunting tomorrow!!
https://www.sau.com.au/forums/topic/22824-mobile-phone-radar-detectors/
Yeh i'm curious to know how well it will work. i guess i've been very lucky with speed camera's. I speed everyday, but unless there really well hidden, i always tend to see them (touch wood)
Even if it only works occasionally, its gotta be better than not working at all.
My radar detector works really well... Its only failed me once in 18months of having one and that was on Greenmount Hill... I was really late for a Doctors appointment in Mundaring so i was hurrying along and they setup a trap round a tight corner, unfortunately by the time the detector went off it was too late, but i did jump on the brakes and slow down heaps and all i got was a $50 fine and no demerit points... :)
My Nokia 3650 beeps before speed cameras for some reason. I didnt pick up on it to start with, but then noticed it was beepeing after I drove past 3 radars and got 3 beeps between Tweed Heads and Byron Bay. It was then I realied that the speed camera was interfering with my phone. :) Nice
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
