Hehehe well its definitely dodgy (like i said i was sceptical in the last line on first post).
I've been past two multinova's (with police blocking them due to strike action :P ) and no beeps / warnings
HOWEVER i did go into the local shell servo and my phone started beeping like crazying..... Odd
Does anyone know what the 5 0's actually do and what those 3 little computers mean.
ok its pretty obviouse that the phone thing doesnt work. or at least not always.
my question is: is there a radar detector on the market that works well and that the police cant detect?
ive heard stories of the police being able to detect the radar dectors.
my good friend is a cop and he say that most of the time dont believe every thing a cop says and there will never be a 100% radar detector never ill tell you 2 things 1: the best radar detector is look for on coming cars that flash there lights that is one off the cheapest radar detectors that is 100% next one wait for it...DONT SPEED
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
