tp1gts2 Posted July 15, 2008 Share Posted July 15, 2008 hey, i have bosch 040 intank pump in my 32gtst and recently went to a drift practice day at baskerville in tasmania, halfway through the day my car started cutting out at high revs or high load, by the time i got home i couldn't rev it past 2500rpm or put much load on it at all and the pump was buzzing its head off the bosch 040 had shat itself, i now have a new one in there and all is good, but im worried if i go back to the track again it will happen again. some people have told me i should get a surge tank, but i cant see how it could run out of fuel(enough to stuff the pump) with over half a tank left ive done the voltage mod and am running the pump off my own relay and it has 14volts going to it, could this hurt it? but maybe i just got a dud pump very grateful for any help! for those interested heres a vid from the praccy day, my first one so go easy!! over Link to comment https://www.sau.com.au/forums/topic/228255-bosch-040-intank/ Share on other sites More sharing options...
GeeTR Posted July 15, 2008 Share Posted July 15, 2008 is the pump pickup using a sock at same height and position as the original? Link to comment https://www.sau.com.au/forums/topic/228255-bosch-040-intank/#findComment-4016552 Share on other sites More sharing options...
wolverine Posted July 15, 2008 Share Posted July 15, 2008 is the pump pickup using a sock at same height and position as the original? the 040 has the open base, therefore no sock. Link to comment https://www.sau.com.au/forums/topic/228255-bosch-040-intank/#findComment-4016751 Share on other sites More sharing options...
bubba Posted July 16, 2008 Share Posted July 16, 2008 I have an 044 mounted intank with a new sock but it's mounted much lower than the original, had a track day and a couple of skidpan days with lots of sideways, no dramas whatsoever. It will even run down way past the E line on the gauge and still not splutter under full load. Link to comment https://www.sau.com.au/forums/topic/228255-bosch-040-intank/#findComment-4016992 Share on other sites More sharing options...
GeeTR Posted July 16, 2008 Share Posted July 16, 2008 the 040 has the open base, therefore no sock. One can machine up a fitting to suit, as per a 044 DIY i did I have an 044 mounted intank with a new sock but it's mounted much lower than the original, had a track day and a couple of skidpan days with lots of sideways, no dramas whatsoever. It will even run down way past the E line on the gauge and still not splutter under full load. Odd, might be worth seeing if you can send the dead pump to Bosch Australia for a pull apart, and diagnostic. Maybe the pickup is too low lol. Link to comment https://www.sau.com.au/forums/topic/228255-bosch-040-intank/#findComment-4017218 Share on other sites More sharing options...
