hey, i have bosch 040 intank pump in my 32gtst and recently went to a drift practice day at baskerville in tasmania, halfway through the day my car started cutting out at high revs or high load, by the time i got home i couldn't rev it past 2500rpm or put much load on it at all and the pump was buzzing its head off
the bosch 040 had shat itself, i now have a new one in there and all is good, but im worried if i go back to the track again it will happen again.
some people have told me i should get a surge tank, but i cant see how it could run out of fuel(enough to stuff the pump) with over half a tank left
ive done the voltage mod and am running the pump off my own relay and it has 14volts going to it, could this hurt it?
but maybe i just got a dud pump
very grateful for any help!
for those interested heres a vid from the praccy day, my first one so go easy!!
over
https://www.sau.com.au/forums/topic/228255-bosch-040-intank/
I have an 044 mounted intank with a new sock but it's mounted much lower than the original, had a track day and a couple of skidpan days with lots of sideways, no dramas whatsoever. It will even run down way past the E line on the gauge and still not splutter under full load.
the 040 has the open base, therefore no sock.
One can machine up a fitting to suit, as per a 044 DIY i did :(
Odd, might be worth seeing if you can send the dead pump to Bosch Australia for a pull apart, and diagnostic. Maybe the pickup is too low lol.
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
    • I made an extension of the item circled above in red that is hard wired to the battery and tucks away nicely in the engine bay, could easily do the same if it in the boot, just run the extended cable out under the bonnet or boot lid, I then just stick the charger on a milk crate to get it off the ground
    • It's purpose will be to stop the regulator plug from leaking oil. As GTS said, if it seals properly, it will mainly just have the effect of slightly higher oil pressure. I'll assume tolerances/fitment in the relief valve aren't that close that the washer being missing won't let it vent at 100% capacity too.
    • I put the charger in the engine bay and run the power cord down through one of the holes in the undertray, or at the back end of the engine bay, any time I need a car to be on a charger outside. In fact, I bring the extension cord up through into the engine bay so that it's not dragging around where it could get wet, or easily unplugged.
