I don,t know why but after 3 weeks of having my stagea ,I discoverered that she is using half a tank every week (@ 100 kms) :P what is wrong ?,I'm beeing nice with my right foot,but every timeI fire her up,1 line of petrol goes down ,also every time I reverse ,it's like i need to accelerate because it feels like something is stoping the front end(i'm new in the land of imports & awd) any advise will be absolutely welcome. :laugh:
I have no mods the car is mostly standard
https://www.sau.com.au/forums/topic/228256-help-memy-stag-is-eating-me-alive/
Sounds like something is seriously wrong, as you already know, could be one of many things, even drivetrain going off your comments. So when you are in reverse on flat does it need accel to move ? or in N can you push it ?
Like all imports, get ALL fluids changed (oil,tranny, transfer, R diff, F diff, brake, powersteer, radiator), plugs/filters changed, as most of them would be original Nissan.
Does it idle smoothly ?
I was at my compliancers the other day they change all the fluids so if it was done when they complied it,it should be ok,from what i have read fuel usage in mostly stock cars comes down to not many things,Heavy right foot (already discounted) O2 sensor, overly high A/F ratio causing it to run rich(excessive fuel usage) Try reset the ecu and see if that helps, If all else fails to the tuners you go.Does the car have any electronic gear in it Sitc or Safc. I know my car was supposed to be almost stock but is far from it when it landed with all sorts of electronic crap that i dont know how to use.
like any industry, a few cowboys around, yours sound pretty thorough, stick with them. As for Freddy's problem, like Andy said, O2 sensor as well, get yourself a highflow exhaust+cat, trashing the cat the compliance shop stuck on. But 100km for 1/2 tank sounds pretty major.
What city are you located in ?
Get your driveline issue sorted before the fuel issue because if it's something to do with the ATTESA then it'll be super-expensive if it breaks!
As for your fuel issue, i'd suggest getting the car dyno'ed to see what the AFR's are doing then take appropriate measures from there.
sounds like you may have issues with the front diff (if you are sure the "stopping" is coming from the front)
The easiest way to check this is going to be to slide under the front, take the 4 bolts out of your front driveshaft and remove it. You will lose AWD (obviously) but you will be able to tell straight away if there is a front end problem.
Oh, and +11ty for not trusting compliance shops. There are DEFINATELY too many cowboys in the industry to trust anyone IMO. I could tell you stories that would make your eyes bleed :laugh:
That was one of my first guessings ,and i did it a couple of times ,on the weekend I will try to jack it and do the other check you tell me.
I live in Narre Warren,near berwick (S.E. subs of Melbourne) If there is somebody on this area ...Do you know any import mechanic around?one you could put your ride on his hands?
My miss is thinking I f**ked again with it :)
Yeah mate.
Call RE Customs in Springvale/Clayton 9548 3414.
http://www.recustoms.com.au/
I live in Pakenham & take my M35 there (they did my Hiflow turbo) and they are pretty bloody cluey.
They do ALOT of work on Nissan imports and know their stuff.
Good guys as well. Small outfit that take pride in what they do.
Ray is the owner there, but I have mainly have Michael & Brad working on my car.... Really good blokes.
Edited by iamhe77
hi freddy welcome to the stagea site, nothing much worse than the 'missus' telling you your a d/head, but things should improve if you listen to the boy's( well most of them),your stagea even with a shitty std exhaust and running sweet should return approx 240km for 1/2 tank(with good system & supporting mods ie panel filter, safc etc you will get consumption better than that). have a good search it's all been discussed heaps, you will find most of the answers here somewhere, goodluck.
ps did you buy the car off someone from here?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
    • Maybe I should have written that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
