I don,t know why but after 3 weeks of having my stagea ,I discoverered that she is using half a tank every week (@ 100 kms) :P what is wrong ?,I'm beeing nice with my right foot,but every timeI fire her up,1 line of petrol goes down ,also every time I reverse ,it's like i need to accelerate because it feels like something is stoping the front end(i'm new in the land of imports & awd) any advise will be absolutely welcome. :laugh:
I have no mods the car is mostly standard
https://www.sau.com.au/forums/topic/228256-help-memy-stag-is-eating-me-alive/
Sounds like something is seriously wrong, as you already know, could be one of many things, even drivetrain going off your comments. So when you are in reverse on flat does it need accel to move ? or in N can you push it ?
Like all imports, get ALL fluids changed (oil,tranny, transfer, R diff, F diff, brake, powersteer, radiator), plugs/filters changed, as most of them would be original Nissan.
Does it idle smoothly ?
I was at my compliancers the other day they change all the fluids so if it was done when they complied it,it should be ok,from what i have read fuel usage in mostly stock cars comes down to not many things,Heavy right foot (already discounted) O2 sensor, overly high A/F ratio causing it to run rich(excessive fuel usage) Try reset the ecu and see if that helps, If all else fails to the tuners you go.Does the car have any electronic gear in it Sitc or Safc. I know my car was supposed to be almost stock but is far from it when it landed with all sorts of electronic crap that i dont know how to use.
like any industry, a few cowboys around, yours sound pretty thorough, stick with them. As for Freddy's problem, like Andy said, O2 sensor as well, get yourself a highflow exhaust+cat, trashing the cat the compliance shop stuck on. But 100km for 1/2 tank sounds pretty major.
What city are you located in ?
Get your driveline issue sorted before the fuel issue because if it's something to do with the ATTESA then it'll be super-expensive if it breaks!
As for your fuel issue, i'd suggest getting the car dyno'ed to see what the AFR's are doing then take appropriate measures from there.
sounds like you may have issues with the front diff (if you are sure the "stopping" is coming from the front)
The easiest way to check this is going to be to slide under the front, take the 4 bolts out of your front driveshaft and remove it. You will lose AWD (obviously) but you will be able to tell straight away if there is a front end problem.
Oh, and +11ty for not trusting compliance shops. There are DEFINATELY too many cowboys in the industry to trust anyone IMO. I could tell you stories that would make your eyes bleed :laugh:
That was one of my first guessings ,and i did it a couple of times ,on the weekend I will try to jack it and do the other check you tell me.
I live in Narre Warren,near berwick (S.E. subs of Melbourne) If there is somebody on this area ...Do you know any import mechanic around?one you could put your ride on his hands?
My miss is thinking I f**ked again with it :)
Yeah mate.
Call RE Customs in Springvale/Clayton 9548 3414.
http://www.recustoms.com.au/
I live in Pakenham & take my M35 there (they did my Hiflow turbo) and they are pretty bloody cluey.
They do ALOT of work on Nissan imports and know their stuff.
Good guys as well. Small outfit that take pride in what they do.
Ray is the owner there, but I have mainly have Michael & Brad working on my car.... Really good blokes.
Edited by iamhe77
hi freddy welcome to the stagea site, nothing much worse than the 'missus' telling you your a d/head, but things should improve if you listen to the boy's( well most of them),your stagea even with a shitty std exhaust and running sweet should return approx 240km for 1/2 tank(with good system & supporting mods ie panel filter, safc etc you will get consumption better than that). have a good search it's all been discussed heaps, you will find most of the answers here somewhere, goodluck.
ps did you buy the car off someone from here?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
